lowering on the cheap - questions
87R10
Ontario, Canada
Scott
I'm thinking of temporarily lowering my SWB by cutting a round out of the coils. Does this mean roughly a 2" drop? Also, what is a simple way to drop the rear about 3-4 inches?
I'm also worried about ruining my new shocks...thoughts?
J Knight
Baytown TX
82 Chevy
350ci
The cheapest way to drop 2/4in on the cheap is to cut 1 round off the front coils(2in), mount the front leaf spring hangers 4in higher on the frame, and install 2in drop shackles. That's about $50-60 in parts plus a front end alignment.
Hoodbj
Billy
I'm interested in doing this also. Do you just drill or cut out the factory rivets on the hanger and measure up higher on the frame and drill new holes and reinstall with bolts? Would this affect the angle of the driveshaft enough to worry about?
J Knight
Baytown TX
82 Chevy
350ci
Yes you have to cut the rivets out and measure then redrill the frame. Use grade 8 bolts 3/8 by 1in bolts with washers and lock washers. Driveline angle changes a little but typically doesn't cause any problems.
87R10
Ontario, Canada
Scott
Thanks - do I run the risk of bottoming out my shocks or do they need to be shorter?
VFL1982
