Internal engine rust treated with Kano ?
Preston
Mechanicsville VA
Preston
I have an engine that was stored for a time uncovered, pulled the heads cleaned up and used a cylinder hone cleaned up good. Pulled the oil pan and oil pump screen is clean looks like may be able to save bottom end looks great. Gonna try to spray some Kano on everything and let it set for a week and see what happens, anyone ever used Kano before? Of course the motor is locked up, just trying to get it back in service will pull the pistons and go with new rings bearings and completely hone the cylinders.
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Kano, like Kroil? I use Kroil all the time, that stuff works great. Not only is it a good penetrant but yeah it will dissolve some rust too. Very light rust, nothing pitted or with scale, but some light surface browning will come right off
Doc_Ellis
Nashua, NH
Keith
Sierra 1500 shortbed
Kroil is the shiznat. Only ever used it as penetrating oil, but it’s the best I’ve tried in that respect.
Tough to find around here so I usually default to PB Blaster, which is a distant second. One of these days I need to pick up another 1/2 gal of kroil though
JIMYB
