Inner spindle bearing?
83chevyk10
Rising Sun, MD
Caleb
350 SBC
I already know, heat and kroil. But does anybody have a good tip for getting out the small bearing inside of the spindle? Bent an old screwdriver so that i could get behind it and pound it out be shes locked in good. Anyone else got a better way of doing this?
Dougnsalem
Deleted. Doug was being
Dougnsalem
Dumb...
Dougnsalem
Ahh hell.... Never mind me. I misread what you asked.........
83chevyk10
Rising Sun, MD
Caleb
350 SBC
You really like torching/cutting **** dont you lol? Think youre prolly right this time. But im talking about the little bearing inside of the spindle i cant get a grinder disc in there. Maybe ill try a dremel with a little cut off wheel?
Dougnsalem
Lol. You are talking the inner race, of the bearing in the hub? 4X4 right? Post a pic.
83chevyk10
Rising Sun, MD
Caleb
350 SBC
No lol. That actually would be a dumb question. Its inside the spindle. I believe its the " inner spindle axle bearing" or something along those lines. There is no race just the bearing. Its about an inch and a half across
83chevyk10
Rising Sun, MD
Caleb
350 SBC
This little guy inside the spindle
Dougnsalem
Same page now. Those normally aren't stuck in real hard (like a race). Close to the back of the spindle. WHACK IT WITH A CHISEL AND 20LB SLEDGE!
Just kidding. A smaller, sharp chisel should cut through it. Bend it in towards the center being careful of the spindle. I really haven't had problems with those. You know, your idea of the dremmel is pretty good....
Dougnsalem
I made a tool from large threaded rod, washers and nuts.
This is a really good idea. Is there a good enough lip showing on the bearing to catch it with the washer? I'm gonna have to remember that....
83chevyk10
Rising Sun, MD
Caleb
350 SBC
The threaded rod idea is genius. Sure i have enough laying around to rig something up like that. Thanks guys
yevgenievich
Place
Name
Year
Model
Size
It worked great for me. Took just couple of hits with a hammer. Washer was sized to barely fit so it would have the largest impact area on the bearing.
Moderator
There's actually a simple tool just for this purpose. Your local parts store might have it in a loaner program.
Moderator Administrator
Every mechanic needs some All thread laying around. Usually in 3/8's and 5/16's sizes. I've made several transmission tools out of All thread using washers, cheap china sockets etc for compressors, and bushing pullers and drivers.
VFL1982
