Hub Covers Replacement help
Jacko Wacko
New York
Jake
R20
350CI
I am trying to find where I can buy replacements for just the pitted chrome parts. Everything else works fine. I found that they are discontinued from GM, so aftermarket would be ok. Can anyone point me in the right direction?
TIA
View media item 9372View media item 9371
80BrownK10
Greenwood, SC
Nate
Try LMC or american racing maybe?
Shorty81
Baby Boomer
North West ohio
Darren
Mine are Crager
Bennyt
Surprise
Ben
Pep Boys or any place that sells tires/ wheels should be able to get them.. I used to see them all over the place. Pretty much universal and fairly inexpensive.
Auburn, Washington
Those aren't "GM" center caps. As said, they're universal and the good news is widely available.
Craig 85
Nashville, TN
454/TH-400/NP205
Check your bore size before buying. I bought a set of wheels for my last truck on CL. I made the assumption the were American Racing, it turned out they were Eagle Alloys with a smaller bore size.
On my K30 I bought stainless caps from American Racing.
WFO
Texas Panhandle
Do you remember what the diameter was on yours?
Mine, on a 14 bolt full float, measure 5" with a tape, but the ones I see online are 4.9" or 5.15".
Craig 85
Nashville, TN
454/TH-400/NP205
The center bore on my American Racing wheels is 5.15". I have an extra AR cap and that diameter is about 5.138" maybe slightly larger as my caliper would not fit over the base of the cap.
The Eagle Alloys I had were smaller. I had originally bought the AR caps and they wouldn't fit in the wheel.
  • Like
Reactions: WFO
WFO
Texas Panhandle
Much obliged.
I thought about buying new ones, then put them on when I rotate my tires. But I reckon I'll pull one wheel to get an accurate measurement.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I have a whole set of new AR ones I didn’t want to use. They send all four closed end, but you can have them for the cost of shipping.
RustyBoltGarage
