Rear glass sash rubber
K5Rob
Maine
Rob
K5 Blazer
Hey guys, tearing into my k5 tailgate, the rear glass sash is completely gone. I found a replacement and the rubber strip that holds the glass into the sash. Apparently you form the rubber around the glass and then press or gently tap the glass into the sash with a mallet. I am skeptical, especially since aftermarket stuff like this doesnt always fit well. Was wondering if maybe windshield polyurethane would be better or maybe a combination of both. What are your guys thoughts?
saltdog
US
K20 Suburban
RTV works pretty good on both sides of that rubber, lubes it up, holds it in.
K5Rob
Maine
Rob
K5 Blazer
Thanks saltdog. My fear is the glass will pop out of the sash due to the older components and just the reputation the tailgates have for friction and not working well. I plan on going manual but its just not in the cards this year and i need it “functional” at least with a cordless drill to be able to do some work around the truck. I have the new sash here and am waiting on the rubber as it is backordered at the moment.
I've used windshield urethane and it works really well. I believe it also helps keep the sash from rusting away because it doesn't collect debris and moisture like the original setup.
However, I do drill a bunch of 3/16" holes through the sash, to give the urethane more to bite onto.
Edelbrock
Earth
Grumba
K5 Blazer
Not sure if this is what your after, but I installed this on my K5 rear window and it works GREAT. Easy to install as well.
Link:
As an Amazon Associate we earn from qualifying purchases.
saltdog
US
K20 Suburban
@K5Rob Had same concerns too but its worked for me without issue for at least 6 years. Urethane is way more PIA to get out just sayin
K5Rob
Maine
Rob
K5 Blazer
Thanks. Do you think the RTV is helpful or just go with the rubber? I do have RTV on hand but not urethane and I know its expensive.
I feel like my post went unnoticed, lol.
Urethane kills two birds with one stone. Not only does it hold the window to the sash permanently, but it also helps eliminate the reason that the sash rusted to begin with.
Yeah, RTV may work ok, but I wouldn't expect it to last as long as I plan on owning the rig. RTV is a sealer, not an adhesive. I'd rather spend the few extra dollars (ok, several extra dollars, lol) on a tube of urethane and never have to worry about it.
Again, if it's said that RTV has worked for you, I'm inclined to believe it. But personally, I'd want to know it's going to last. Redoing a failed previous repair is often a much bigger pain in the ass than doing it the right way to begin with.
saltdog
US
K20 Suburban
@bucket that's definitely a good point and windshield urethane is good stuff. RTV is available pretty much everywhere locally, urethane is less so, but with Amazon, its not usually a big deal. I've done several of these used RTV with the rubber and without and 3M-5200 Marine Urethane which is similar to the windshield urethane but somewhat harder to remove. I've never had a sash rust-out because I've always prepped and painted before doing the repair but yeah-its a PIA and who wants to do it again. Urethane is a great option with or without the rubber.
K5Rob
Maine
Rob
K5 Blazer
Well i installed the glass into the sash using the rubber and urethane. First I test fit dry using the rubber and the sash basically slipped right on, not very tight at all. I then laid a bead of urethane in the sash, got the rubber just started in the sash, then a bead of urethane in that, and then pressed the glass in. It was much tighter as the urethane takes up space. I didnt really think of this beforehand. Had to seat the sash to the glass with a rubber mallet and it went hard. I believe its fully seated but obviously can only see the ends. I am letting it cure over night to be safe. It did make a bit of a mess and i will have to try to clean up with a razor tomorrow.
Wondering how close the sash gets to the weather stripping when rolled all the way up? The sash rubber sticks out a bit and not sure if i should try and trim it flush. In hindsight i think i would have just direct urethaned the glass to the sash but oh well.
Heartland Dream
