I am trying to find where I can buy replacements for just the pitted chrome parts. Everything else works fine. I found that they are discontinued from GM, so aftermarket would be ok. Can anyone point me in the right direction? TIA 20210120_094555 by Jacko Wacko posted Jan 20, 2021 at 10:39 AM 20210120_094547 by Jacko Wacko posted Jan 20, 2021 at 10:39 AM
Pep Boys or any place that sells tires/ wheels should be able to get them.. I used to see them all over the place. Pretty much universal and fairly inexpensive.
Available in various styles. https://www.summitracing.com/search...ordMatch&SortOrder=Ascending&keyword=hub caps
Check your bore size before buying. I bought a set of wheels for my last truck on CL. I made the assumption the were American Racing, it turned out they were Eagle Alloys with a smaller bore size. On my K30 I bought stainless caps from American Racing.
Do you remember what the diameter was on yours? Mine, on a 14 bolt full float, measure 5" with a tape, but the ones I see online are 4.9" or 5.15".
The center bore on my American Racing wheels is 5.15". I have an extra AR cap and that diameter is about 5.138" maybe slightly larger as my caliper would not fit over the base of the cap. The Eagle Alloys I had were smaller. I had originally bought the AR caps and they wouldn't fit in the wheel.
Much obliged. I thought about buying new ones, then put them on when I rotate my tires. But I reckon I'll pull one wheel to get an accurate measurement.
I have a whole set of new AR ones I didn’t want to use. They send all four closed end, but you can have them for the cost of shipping.
