Cblaho81
- Mar 16, 2026
- Ohio
- Curtis
- C10
I am looking for suggestions on what gear ration do swap to. My current set up is a 1983 Chevy C10 with a built 355 small block, 3200 rpm torque converter, 700r4 trans and 3.73 posi rear. With the current engine/cam combo i can not use 4th gear unless I am running above 70 mph. The cam was originally specked for my 1975 Chevelle with a 3500 rpm converter, TH400 and 4.11 gears. Cam specs are as follows; Comp Cams 284H Hydraulic Flat Tappet, .507/.510 Lift, Duration @ .050 - 240/246, RPM Range 2300-6500. I do not want to change cams as this one sounds and runs great. I am pondering two options:
Option 1: Swap trans to a TH400 and change to 4.11 gears
Option 2: Swap the rear gears to either 4.56 or 4.88 so that I can use 4th gear in the current set up.
I am looking for information if anyone else has had this problem and what the best solution would be.
Thank you
Curtis
Thank you
Curtis
