Garage And Shop Safety
I'm late to the party, but no breaker bar extensions on your ratchets? W/out and impact wrench, I couldn't do 1/2 the stuff I need to do w/out sliding my trusty 1-1/2 galvanized steel pipe over my ratchet!
Technically true. You don't want to use a cheater pipe on a ratchet. The ratchet has a stop mechanism that will only hold so much. If you put a cheater on it, and you're giving it hell, and the mechanism breaks, then you can be hurt. It is much safer to use a cheater pipe on a breaker bar.
83K5guy
Corpus
Justin
K5 Blazer
if possible wear face shields, a friend of mine was wire wheelin some parts and a wire come off and stuck right in the middle of his forehead, almost so deep you couldnt get tweezers on it and then he bleed like a stuck pig, oh by the way maybe having a home made first aid kit handy. the ones you get from the store sometimes are a joke
davbell22602
Bunker Hill, WV
I Dont
Have
One
Who sells the face shields?
proddy2008
texas
patrick
silverado 3500 dually
350/sm465/d70hd
open flames and welding are not the only dangers around a gas tank..... grinders too about 4 years ago my dad and i were working on a camaro and there was a hole in the tank under some sheet metal so instead of dropin it he grabs a grinder and starts cutting.... i grabed fire extinguisher and waited well tank went up and so did he luckuly had extinguisher so only for a couple of seconds used whole bottle on him so had nothing for the car btw water WILL NOT PUT OUT A GAS FIRE
proddy2008
texas
patrick
350/sm465/d70hd
oh if you take the straps hinges or whatever it is that keeps a door open and just let it free there watchout for wind
Good Points above !!!
Always gotta be careful where grinder sparks go.
proddy2008
texas
patrick
350/sm465/d70hd
yep crispy=good on chicken not so good on you
I did this the week my tires got slashed, I borrowed my brothers truck and the driver's door bit me when I wasn't looking, fuggin hurt.
attachment.php
Did I read that right???? You used a grinder near a gas tank??? :think:
proddy2008
texas
patrick
350/sm465/d70hd
lol HE did i grabed a fire extinguisher and said dont do it man! kids these days just dont listen
imyourhuckberry
