- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I'm late to the party, but no breaker bar extensions on your ratchets? W/out and impact wrench, I couldn't do 1/2 the stuff I need to do w/out sliding my trusty 1-1/2 galvanized steel pipe over my ratchet!
Technically true. You don't want to use a cheater pipe on a ratchet. The ratchet has a stop mechanism that will only hold so much. If you put a cheater on it, and you're giving it hell, and the mechanism breaks, then you can be hurt. It is much safer to use a cheater pipe on a breaker bar.
