Dutch Rutter
- Aug 13, 2013
- Independence, Or
- Joshua
- K20
Hey all,
Finally starting to tackle some of the other on going issues I've been having with my 84, this is probably going to take me a while to fix. After driving the truck (a bit more noticeable on hot days) after shutting her down I hear a "hisss" sound and get a huge gas smell from between the bed and cab. I will also experience the same thing when driving on a warmer day with the back glass open. I can open the tank I am running and it will depressurize which stops the hiss, and smell.
A quick search and I was reading about the lines leaking between the tanks and the pump would this be accurate for my problem or would the fuel pickup in the top of the tanks needing resealed be more so what I'm looking at?
Both tanks work, the passenger side does it more then the driver's for some reason. And to my knowledge there is no emission stuff on this truck, had to of been removed by a PO.
Thanks for the help.
