Front Brake hose stamped nut
ChuckN
Bellinham, WA
Chad
Anyone know where to buy one? One of mine gave way and is shot. They didn’t include them when I purchased the new hoses. Hell, even if I could get some kind of a clip, I imagine that might suffice as it’s not a high stress item. Another thread referred to them as a 15/16”, someone must sell them. Thanks in advance.
Bullet Bob
Louisiana
Robert
15/16 is what size wrench I had to use the other day to fit the one on my truck. You may be able to use a washer and thin nut that’ll fit the thread on the rubber brake line. Might get you out of a bind until you find the correct one.
bluex
Spartanburg SC
C15
If you have your old one still take it to the hardware store an you can get a regular nut to replace it. I've done it in the past but can't recall the thread size.
ChuckN
Bellinham, WA
Chad
If you have your old one still take it to the hardware store a you can get a regular nut to replace it. I've done it in the past but can't recall the thread size.
Yeah, that’s what I was thinking. It’s pretty deteriorated, might have to get a brake hose from a store, take it down to the local Hardware Sales (they have a few aisles of nuts and bolt- it’s pretty awesome actually) then return the hose after I’m done.
I did some digging on the internet, someone posted that it was 5/8 fine thread. I’ll post whatever I find.
Strick
Dunn, NC
Harold
C20 Crew
I believe the thread may be 9/16‐18. I ran into a similar issue recently with the parking brake cable.
HS
ChuckN
Bellinham, WA
Chad
HS
Cool. I bought both 5/8 and 9/16. I’m out of time today, should have an answer tomorrow.
I still have one that's just hanging out, stuck forever dangling on the hard line lol. I put Wilwood braided stainless lines on and forgot to grab the one off the driver's side
ChuckN
Bellinham, WA
Chad
Are you sure that I wasn’t there helping you? I’d have done the same :emotions33:
ChuckN
Bellinham, WA
Chad
HS
Confirmed, is 5/8 fine thread. I just cut a notch in the nut, cleaned up the threads, and spun it on.
wisco11
