exhaust-motor mount clearance
Camar068
10 yrs Air Force
How much clearance do I need between the exhaust manifolds and the motor mounts?
I'm putting a '75 350 in an 86 K10 using the 86 motor mounts. The driver side, from what I can tell, is touching the top side of the motor mount.
Can I use longer bolts and "lift" the engine using spacers/washers between the mounts and engine?
The '75 mounts looked the same but I didn't spend a lot of time comparing. I put the exhaust on after the engine was installed, not prior.
Thanks In Advance
'Maro
Camar068
10 yrs Air Force
Just notch the clamshell mount enough that they don't touch.
acesolis
