R4 Compressor Help
texasmike
Conroe Texas
Is there anyone on this site that has had any success with "NEW" R4 compressors being sold by the usual vendors: O Reilly, Auto Zone, Parts Geek, Rock Auto, and even a GM dealer in my location. I am having the fifth (5) one in the last five years replaced next week! The first two were Murray compressors and both started leaking at the front seal. The third one was furnished by a GM dealer and also started leaking at the front seal. All three of these units were installed by the same shop so I decided to try a different one. I found a mom and pop shop, highly recommended by friends, and they installed the fourth compressor on July 30 last year. They had told me that seal failure can come from overcharging the system. This one is a Four Seasons kit (accumulator, orifice tube, compressor) from Auto Zone. It worked fine until a month ago when it started making a random noise but still cooling fine. The shop said they would replace it under warranty and told me to stop using it before it possibly trashes the system.
My research has indicated that ALL of these compressors are made by Standard Motor Products, Lewisville TX, at a plant in Mexico. I have been dedicated to, and trying really hard, to keep this truck to as close to original as possible. I am retired and when I have to leave the house, this truck is my first choice. I drive about 200 miles a month and love using this fabulous machine.
Thanks for your input.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
Four seasons says to add the oil to the compressor then stand it on end for 1-3 minutes to lubricate the front seal. I would doubt the shop is doing that.
Also if your compressor had a mechanical failure debris may be floating around the system and taking out the new compressor. You should make sure it is flushed well after replacement.
The R4 was never a great compressor.
I have yet to talk to anyone that has had long term success with an R4. I know you want to keep it original, but you're fighting a loosing battle with the R4. Everybody I know that drives their truck alot has converted to a Sanden compressor, small block, big block or LS engine.
sublimeobs
NELA
Pigpen
Our experience is similar. If you're really wanting to keep it OEM, look for a NOS R4; they're available and not terribly expensive.
Here's one on fleabay for $500.
I put an OE unit on my 1995 GMC in 2005 or so and it's still going strong.
91burb2500
Plantation, FL
Joey
Suburban R2500
I went through one aftermarket and two delco R4s before I switched to a Sanden. Expensive as hell in comparison, but it was worth it. I’m running a 5.3, so went with the Holley kit with brackets/idler pulley and it works great. They were the only ones that had the right fitting angles to line up to the oem hoses. Also crucial was upgrading to a new style cross flow condenser, night and day!
fast 99
Spokane, Washington
Have seen a bunch of them fail.
That being said, our company had good luck both R12 and 134A units. Several trucks had 300k on original compressors. Had all the equipment to recycle the refrigerant. Generally any time the compressors were in the way I yanked em, just easier. During recharge usually added 2-3 oz of oil so they were always well lubed.
On customer vehicles with knocking units most I have seen are dry, out of oil. Not sure what others have experienced but most of the internal failures are probably lubrication related.
Full disclosure, replacing the R4 my SB this week. 2 year old SMP Temp Chinese. O ring is leaking on the case to housing seal, it's not an internal failure. I tried to buy a US replacement, unable. Have had decent luck with AC parts even though some or most of it is made offshore. We will see.
In retrospect, would have converted to an updated design. The replacement original units are questionable.
Trucksareforwork
Spartanburg SC
Geoff
I have had good success with a delco brand R4 I bought new about 3 years ago.
JBswth
Vallejo, California
James
C25
292 cubic inches
I would switch to an A6 or a Sanden. If you switch to an A6, you might have to change some other components, but you will have a reliable compressor.
J.B.
bigy8s
