Engine Backfire Diagnosis Led to Wiped cam Lobes
350runner
tx
Ceasar
Ok are the pcv and break booster currently connected to the big port on top or bottom?
Skweegle89
Oklahoma
85swb "Fancy"
by the way, I wanted to point out that I stand behind my work, so if anything is determined to be carb related, I'll take care of it, so don't worry about that.
Your a hell of a fella. I really don't think it's internal. Me and one of our mechanics are about to dive into it and will report back with what we find.
Skweegle89
Oklahoma
85swb "Fancy"
The pcv is on top on the front. Booster is on the bottom on the front.
Skweegle89
Oklahoma
85swb "Fancy"
Is this incorrect?
350runner
tx
Ceasar
Yes cap the top port and run pcv to the bottom, booster to the back
Skweegle89
Oklahoma
85swb "Fancy"
The only one on the back is on the very top by the back. It's too small. The booster line just falls off it.
Carb'ed Vortec 350
My booster is on the back, connected to a 3/8" piece of stainless tubing that is bolted to the bottom plate of the carb. It's a large port I know that, and it's not connected to the manifold, there is another port back there too but it has a 3-legged tee, and my cruise is hooked to it as well as the line to the trans and something else.
Carb'ed Vortec 350
Starting to sound like a vacuum leak. Make sure the 4 carb mounting bolts are very snug
This is another thing I need to check regarding the stumble I'm having on mine, thanks for pointing that out.
350runner
tx
Ceasar
Re: 85swb "Fancy"
Ok do you have a T fitting on the intake between the carb and distributor?
350runner
tx
Ceasar
Re: 85swb "Fancy"
Yes. The big port is and overflow vent and is usually connected to the charcoal canister.
350runner
tx
Ceasar
Re: 85swb "Fancy"
This is the T fitting I'm speaking of. This is another location for the booster to go. It's where I have mine connected.
Skweegle89
Oklahoma
85swb "Fancy"
There is a T in the back of the intake. 1 side runs into the firewall. The other side is cut off
350runner
tx
Ceasar
Re: 85swb "Fancy"
No prob sometimes it's the little things that matter :)
350runner
tx
Ceasar
Run the booster to the T :)
Skweegle89
Oklahoma
85swb "Fancy"
Well it was sucking air between the gasket and the intake. Took the thick gasket off and put my thin one on that came with the adapter. Idles much better now, but lost all my pep. It is gutless now.
crowe-t
