Dana 60 front axle
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
I saw this Dana 60 front axle on Facebook marketplace for $400.00 and had to jump on it. It's a 3.73 ratio and it's tight. Newer rotors and calipers.
yevgenievich
Place
Name
Year
Model
Size
I would jump on that type of a deal too
ajd89
Central Michigan
andrew
Good deal!!! I paid twice that for mine!
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Just cleaning one up is worth $400.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Score!
I'd have bought that even if I didn't need it.
Moderator
Helluva deal!
Do those big castors roll through the yard well?
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
Helluva deal!
Yeah, LOL I had to do that because I have no level pavement when I swapped out my G wagen engine .
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Excellent deal even if you don't have a dually to put it under. If you plan to convert it to SRW spindles expect it to cost you about another $500. But really that was a great buy. I paid $700 for mine, crusty rusty, had to change spindles, new brake calipers and pads, new kingpin bushing kit, new re-gear...I have way too much in mine.
Craig 85
Nashville, TN
454/TH-400/NP205
Great score! Those go for $1500 and more out my way.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
You all realize that until you swap out the stub shafts to D70 parts, the D60 shafts are no stronger than a D44...
nvrenuf
Mobile, Al.
You all realize that until you swap out the stub shafts to D70 parts, the D60 is no stronger than a D44...
I'm your huckleberry, educate me please.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
nvrenuf
Mobile, Al.
The outer stubs are not the same diameter. Spline count also plays a factor in strength, again not the same.
I'm very familiar with the D60 Bible you linked -
1978 and later Stock Dana 60 outer 30 spline stub shafts (pn 40955) are 1.3125" at the splines (major diameter) and approximately 1.250" at the shank.
For comparison, A Dana 44 19 spline stub measure 1.155" at the splines and 1.060" at the shank
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
Yup, the seller took
I'm leaving the front axle as it is and putting dually adapters on the rear.
SquareRoot
Lol. I'm sure the GM engineers collectively decided to build a bigger, stronger axle and then throw in an inferior "weak link" just for the hell of it.
NateP350
