Dana 60 axle play
Trucksareforwork
Spartanburg SC
Geoff
I was able to get the tie rod installed but realized i had boogered the threads on the steering damper stud when disassembling the old one. So I need to get a new stud.
The bushings look old but centered until I get to the rear driver side, which is way off center. So I’m going to add that to my project list.
I did start it up and let the drivetrain roll in 1st gear on the stands just to move everything. I have a leak in the back of the power steering pump that I need to address but everything turns.
Pics of bushings.
This one is the off center one:
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
That bushing is toast. You won't get a good alignment until you get a good bushing in there.
My 1987 steering wondered when driving. The right upper shackle bushing were it goes through the frame was all but gone. I can't wait to drive it now.
nvrenuf
Mobile, Al.
Don’t forget to check the bushings at the top of the shackle too.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Those bushings are junk. I swap all my front spring rear hangers to the ORD hd's. You can get a full kit with the hangers and bushings.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
If your springs are old, I would replace them. They are not very expensive. Just make sure you get the right shackles for the rear of them.
I replaced the springs on my 1987 V3500 and had trouble getting the correct shackles. Many places listed ones that are too small. The spring shop where I bought the springs had them on backorder.
Trucksareforwork
Spartanburg SC
Geoff
Oh the springs are old. I’m going to get it driving and then may do upgrades there. It’s a farm truck that I have a vision for eventually but right now want it to just run and drive because it’s in the way.
EDIT: I'm going to do the front springs. Spent some time looking closely and I'm thinking they are saggy already. I'll use the truck offroad quite a bit and the more I look at this thing, the more I realize I'll be happier if I just buy once cry once.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
Smart move. I am not sure you can do the spring eye bushing in place without a ton of difficulty. So removing the springs only to replace them later seems like a huge waste of effort.
Sometimes you just have to do things right.
Trucksareforwork
Spartanburg SC
Geoff
Yeah, that's what I started to think. That's also what leads me to pour a few thousand bucks into a truck that I was just gonna freshen up. :)
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
I know the feeling. My restoration started out as "I want to fix the old truck up so I can use it around the new house. Dump runs, Home Cheapo runs, etc." Well it turned into a full blown restoration costing more than a new truck. Now I need to find a beater. My wife is going to kill me.
Trucksareforwork
Spartanburg SC
Geoff
Still haven’t done the springs, but did put the wheels on and take a short drive around the neighborhood. The brake, axle, and hydro boost work seems to be great.
A long way to go but figured I’d post about the first drive since all the axle work. (I do have a bed to put on).
Trucksareforwork
Spartanburg SC
Geoff
On springs: I got one side done over the past weekend, new shackles, bushings, springs and u bolts. I got a kick out of how the side I fixed sat a full 2 inches higher than the side with the old spring still on. I think the springs were a little tired.
Trucksareforwork
Spartanburg SC
Geoff
Got the driver side spring in. Good news! The driver side still sits lower. The Chevy lean continues.
Trucksareforwork
Spartanburg SC
Geoff
Had on my front end checklist to “torque pitman arm.” Torque setting from the interwebs? 180 ftlbs.
Sheared off my nut threads.
Pitman arm still intact.
This is why I can’t have nice things.
nvrenuf
Mobile, Al.
@Trucksareforwork you killed the pinch bolt on the pitman arm? If so, grab a grade 8 bolt and lock nut from a hardware store and Google the torque based on bolt diameter. I usually just run it down with my air gun a few ugga duggas.
I’d bet the 180 ftlbs is for a 2wd pitman arm.
Trucksareforwork
Spartanburg SC
Geoff
Yeah. I think I’m lucky. I sheared the threads off the nut. Bolt looks good. I just ran a thread chaser over it.
And yes, I’m sure I screwed up on torque spec. 2wd nut is the retainer for the arm. 4wd the bolt cross locks the arm in via a groove in the steering box output shaft. I’ll just lock tite it and run it to 80-90.
duncan_schawalder
