Carb air cleaners, thermacs, and spacers
84-C20
Chevrolet
I probably should mention when I got my truck it had a little tiny air filter maybe on 8" around, barely bigger than the carb top opening. Yes it cleared the distributor, but that's honestly a terrible setup. It's just to tiny and the only company making replacement filters for that was edelbrock, and damn near $20. I'm sure that small of air filter is restrictive, plus they get dirty so much faster due to less surface area. Since my factory air filter housing is gone I bought a generic chrome air cleaner that's 14" around 3" tall and wix makes a replacement filter for it. The only thing is the new filter housing wouldn't clear the distributor so I bought one of these. https://www.oreillyauto.com/detail/...mount/6411g/4514351?q=air+cleaner+riser&pos=8 Picked the one that worked best and that is that. I would like to go back to the factory air filter housing before winter comes so I can have the thermac back.
Yay good thinking. My truck is just generally gonna be running a LOT better this winter and that was a huge improvement itself over the previous year. And having better driveability when cold blooded will for sure help it's main function it's used for lol. Not often I get up and need to go quickly tho, but definitely helps if I have the option. Like if it's clear windshield and I need to move some snow to get in somewhere etc. Find it lot easier to stall when cold.
Battlac40
New Mexico
James
K1500 Sierra Classic
Sounds like a problem with a dropped base air cleaner. It has been proven that dropped and raised base air cleaners reduce HP/TORQ/CFM. Food for thought...
tell me more o wise one
Dutch Rutter
Independence, Or
Joshua
Guess I've never had this problem. I've always ran at least a 1" spacer under the carb. Gains clearance for the filter base to dizzy. Also helps prevent vapor lock issues.
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
Adds better performance too
Dutch Rutter
Independence, Or
Joshua
This is what I hear. I was able to tell more of a difference when I ran a open spacer on top of my dual place rpm performer and under my old 1406 even though edelbrock says not to (something about carb signals or something)
Now I'm using a 4 hole spacer onto of that same intake and a 1405 edelbrock that i concerted over to an electric choke. Seems to be running well. Can't really complain about either setup.
84-C20
Chevrolet
Torque I'm not sure if it would really change torque much on a low revving V8, where peak torque is at relatively low RPM. Horsepower maybe a tiny bit, if the drop is enough to effect air flow. On a built engine producing high HP & TORQ I can see why you'd want to avoid it, but I'll tell you I can feel it in the seat of my pants.
Of course I've put spacers under carbs for various reasons most commonly for peculation problems, I'm just thinking if there isn't a perc or vapor lock issue that it wouldn't be worth while to remove the carb to add a spacer when a carb to air cleaner spacer will do the trick and it goes on in about a minute. Do you guys think a 1" spacer increases performance enough to feel it on the road?
Dutch Rutter
Independence, Or
Joshua
@SirRobyn0 I totally understand the simplest fix is the best 99.9% of the time. And in that regard agree whole heartedly.
However, the other added benefits (not including any power gains) of a carb spacer are pretty desirable alone. Some people do say that they needed to mess with the carb settings when adding a spacer. If your not too familiar with adjusting the carb it can be a pain.
I personally did notice the performance gain mainly in responsiveness. But more importantly the drive ability. All of this can be personal taste and or feel. Adding a spacer to a otherwise stock engine. I have no idea. My small blocks have never been factory.
People who know more then I do, say adding a spacer is essentially the same as adding larger intake runners. Having a spacer which doesent have a squared off exit would be ideal for fuel vaporization (or whatever its called). And the normal rule of thumb is open spacer for single plane intake, and 4 or two hole spacer for dual plane intake.
Like I said above, I had good results with a open spacer on a dual plane intake. Don't know how or why but it worked. Kind of the same principle of shaving some of the upper division plate on a dual plane intake.
82sbshortbed
Why like that?
SE Texas
Doug
Here's two different spacers for 2 different carbs. The one on the top is a 3/4" adapter plate for a Quadrajet. Bottom is a .830 thick plate for an Edelbrock carb.
I have the adapter plate for it on my BB because I swapped out the half a POS eddy carb for the Quadrajet.
Had it on my sbc Edelbrock performer eps intake before putting it on the BBC and it had way improved throttle response that I could actually feel.
I think I'm gonna do this when I rebuild the sbc. Haven't decided yet.
That's with the spacer under it.
Plates are cheap and come with gaskets and are easy to install. I'd get one but, that's me. I think you can tell enough improvement to warrant the plate or spacer. Whatever you want to call it. Lol
Dutch Rutter
Independence, Or
Joshua
Alot of different styles available. Mine is even different then the ones 82shortbed listed. This is the one I'm using now with good results.
https://www.summitracing.com/parts/sum-g1412
Before I had just an open aluminum one. I've read that the aluminum ones are not as great with insulating the heat as a wood or plastic one. I really didn't notice any difference between the two materials though. I also second the cheap enough for the benefits. Just make sure to sandwich it in gaskets. Don't want any leaks.
Mine being squared off holes i imagine I am leaving some gains on the table. Ideally you want the intake holes rounding out to a larger diameter as it gets to the intake.
84-C20
Chevrolet
I understand the principle of the spacer plate, or adapter riser. I think part of the idea is increased fuel atomizing. What I question is if for example one is added to an existing engine whether it is stock or built no other changes made will it be enough to feel. I'm not asking anyone in particular to answer the question, it is more one of those curiosities I have.
Johns C10 Hubcap
