best bolt on performance mods
Nick.koehler6
IL
Nick
350 5.7L
Best bolt on performance mods..going to a car expo and have some cash..chevy 350. Has edlebrock 600cfm carburator. 1406. I have dual flowmaster 40's.
Depends on what you currently have going on. Is the motor stock?
rich weyand
Bloomington Indiana
Rich
Best performance mod is probably a broadband A/FR meter so you can tune the carb properly.
firebane
Calgary, AB
Curtis
I agree with Rich and the wideband.
JRandle
Verden, OK
Jesse
Chevrolet Silverado
Which A/FR meter would yall recommend?
Sent from behind you.
rich weyand
Bloomington Indiana
Rich
As an Amazon Associate we earn from qualifying purchases.
olemans85
South Jersey
Aden
358 roller
Hi Rich,
This will work with a Qjet carb?
From a '85 305, reusing on a 350.
rich weyand
Bloomington Indiana
Rich
Any carb. All carbs have the same goal, to create the optimal air/fuel mixture. They don't do it as precisely as fuel injection, because fuel injection has a computer monitoring an O2 sensor in real time -- it is a closed-loop control system -- where a carb is adjusted and then runs open-loop. But you will never get a carb to its best settings without a meter so you can dial in the carb settings to get the mixture right.
An A/FR meter hould be the next thing you buy after a timing light. THEN worry about headers and manifolds and carbs and and advance curves and exhaust systems and all the rest.
350runner
tx
Ceasar
super charger....
350runner
tx
Ceasar
:gathering:
Jacknife
Va.
James
K-25
Hi Rich. I assume that you have to weld a bung in the exhaust system for the sensor? A sensor kinda simular to a o2 sensor is what give you your readings ,Right?
Thanks for your advise.
Green79Scottsdale
G.R. - MI
Bob
Yes.
JohnJ1984
