The 4 bolt main LIE !!! Or is it???
Moderator Administrator
That makes sense kind of lol.
The one that I dont get is "RV" cam. I've driven 2 RV's in my lifetime. One was a big Winnebago/cousin Eddie type with a 454 that topped out at about 60 mph and other was the smaller van/camper combo with a 350 that could run about 80 flat out. Underpowered low compression slugs, but they would get you there....eventually....but not how I want anything I own to operate.
So for the last 25ish years now of reading it on the Internet, I’ve asked people when I see them in an older RV, if they've put an RV cam in there RV??? I get some funny looks but the answer has always been no.
How did the name come about if no one is putting an RV cam in there RV and the stock engines were no different from any other engine of its time?
RV cam means really nothing other than a bit over stock and the grind is tended for more torque at lower rpm kinda like what Peanut Port Big Block heads do, and they actually do that. Peanut Port heads are NOT race car heads, but I'll assure you, they're very very underrated and 450hp is certainly possible with a mild cam, meaning a couple steps over an RV cam, thats a couple steps over a stock cam. I never used the 3/4 or full race cam terms. I did use RV cam terms occasionally cuz that's what I used or put in someone's ride. Someone who wanted a bit more torque for towing for example, I'd call it, install you a little RV cam and make some more bottom end torque so you can tow your boat and make it up them little hills without straining.
Don’t forget the 750 double pumper!
And 110ll av gas!
Did I not mentioon Av gas in my list? I thought I did, I meant to. May have missed it cuz I had several at the same time, but for sure, AV gas was one of them. hahaha, your guys must have been slow. We did 850 Double Pumpers. LOL, Well I didn't. I knew better. I did run some 600 Vacuum Secondaries and some 750 mechanical secondaries, since you could do that with a manual transmission fairly easy, but never ran double pumpers. And of course to some of those guys, everytime they seen a dual feed carb, it was a DOUBLE PUMPLER. Pffft, NO IT'S NOT !!! yes it is, I seen the dual inlet tube. OK so what Dilbert Dip$hit, just cuz it has dual feed, don't mean it has 2 pumps. It's still got just 1 accelerator pump on the primary bowl, it's NOT a DOUBLE PUMPER. LOL, I loved that arguement and it was had often.
For the new generation/LS, etc, the “3/4” moniker has been replaced with “stage 2” or “stage” whatever. Every one has a “stage” cam in it. Which makes no sense, because of course, there’s no consensus on what the stages are.
Back in high school, we just said “stock” or “built “.
“Man, that guys got a built 350 in that thing”, which really meant it made about 300hp.
yeah, cuz you didn't BUILT a stock one, they put themselves together. haha, but yeah, you're right. It's a "Built 3 fitty" That meant it's fast !!! NOT !!! hahaha
We lied and said our 265 was a 327 :shrug:..........and hoped no one looked to close?
We we're the other way around. Trying to sand bag. It's a 283 when it was a small block 400. That one was hard to get by with on some of the guys cuz they knew that 400 balancer when they seen it, and cuz a 400 is external balanced, it certainly had a different balancer than the other small blocks did. I could tell the difference in a small journal balancer and a large balancer so when they said 283, which only comes in small journal, then I knew they were full of $hit when I seen the thicker balancer on it. So it could have been a large journal 327 or a 350 but for sure not NOT a 283. But see, for the longest time, I knew everyone knew Chevy engines and I always liked to be different than everyone else. So I did run Pontiac and Olds for awhile. Cuz people didn't know Pontiac and Olds engines. And with Pontiac, there is no such thing as Small Block or Big Block. 455 Pontiac is the same LOOKING block as a 326, so I could easily mislead and just call a 455 a 350 and they didn't know any different. And I also liked to surprise people. It's not hard to do. For example, a Chevy Nova was the same body as Olds Omega, Pontiac Ventura, and Buick Apollo. So I'd pop the hood on my Chevy Nova, and it's a got a BOLTED in Pontiac 455 in it, looking like a Pontiac 350. I just took the motor mount pads out of a Pontiac Ventura at the junkyard, mounted them to my Chevy Nova frame and bolt it in just as if it was a Pontiac Ventura. Also ran an Olds 350 in a Nova for awhile too. Same deal as Olds Cutlass, Pontiac Lamans or GTO, Buick GTS or Skylark I think it as called, was the same bodies as Chevy Chevelle. I did have a buddy, his dad was in Buick big time, I showed him how to put a Buick 455 in a Chevelle and he was winning lots of races. And all those, Buick, Pontiac, and Olds, all made a 350, so you just said, it's a 350 when it wasn't. Had to lie to have the advantage to set up a race and not have to give up any space or give up the move off the line. I liked straight up and flashlight, which was another term I could have added to the list. Chase is a Race, Give me 2 and the move, I want straight up and a flashlight, or straight up and an arm drop, same thing. We did have some terms back in those days. This thread turned into bringing all those memories back. Fun Fun times for sure. Ad we talk about how fast we were now,, pffftttt, is that all? Yep, we were slow compared to now days. Technology has gotten crazy and why they race 1/8 now. To damn fast for the street, people would be dying without a doubt running 1/4 mile now. Street cars running high 8's and 9s in the quarter. FAST and I mean FAST to us was 11's. Anything in the 10's was usually trailered but that didn't happen often, we drove our $hit to the street races. We drove our daily drivers to race. If you broke, you'd be looking for a ride to work Monday morning or fixing it all day Sunday with no sleep at all. Great Times and memories without doubt. Oh and running from the cops too. All good fun. We had 1 street we raced on, we called The box. Cuz it was just an L. You could come off a short side to that long street we raced on, or you came in from the other end of that long street to get there. It was a litteral L. The cops just block the 2 ends and we were stuck. SO THE COPS THOUGHT. I happen to work at a business that backed up to that long street and it had a back gate to the yard, and then that yard, you could go beside the building and out the front parking lot of the business and you were free. So yeah, you wanted to be MY FRIEND if you raced at THE BOX, cuz I had a key to that back gate and we could escape, lock the gate back up and every else that wasn't my buddy, they got popped. hahaha Name of that street was Greenstone Ave in Santa Fe Springs, CA if you wanna google map THE BOX and see what I mean. If it's still there, the place I worked at was Steelform that the front faced and had a Shoemaker street name address, and as said it backed up to Greenstone.
@HotRodPC ever since I first joined here I always loved to read your posts. It’s good to see you cracking the whip again and sharing your experiences with us.
Love you brother. You're probably the only one that reads that $hit. I don't mind it occasionally going down memory lane. Especially when I'm in a bad head space and ready to toss in the towel.
Moderator
Hey now, you know I always read your novels too. At one point, Cob accused me of making posts like yours even, lol.
Love you too Dawg !!! Yep that's Cob though. He's a 2 liner guy. Any more that that his ADD goes nuts and he loses all control and can't comprehend sooo.... hahaha Poor Cob !!!
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
I remember when you were Mr one to five word response guy.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
That was a while ago. I'm full of hot air now :rofl:
I think it was Retro that was the popcorn response dude...
No words, just
:popcorn:
CubsFan79
