GMC-IH
dragstews
GMC-IH
Belleview Florida US of A
Jesse
Body 1954, frame 1975
R-100
406 ci SBC
On the 496 motor that's in the run stand for doing the break-in.
Been having some problems with the used Hunt dist. after sending it to them and having it rebuilt it still don't work.
Decided to use a new Accel HEI instead ...
Fired right up ...
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Bout that time ..
Going to have a nice home ..
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Seems that I jumped into somewhat of a job on my old truck ..
Had the vacuum brakes from the 75 K15 donor truck on it for years, it worked alright but I've got to thinking about swapping the vacuum booster to a hydroboost unit ..
Did some junkyard scouting and found one that was on a 1999 C30 ..
It followed me home ...
Marrying it to the K15 shi errr stuff turned into somewhat of a chore ..
Changed out the M/C to a new 1980 K20 which had a 1.125 bore .. the C30, being a 1 ton truck has a 1.250 bore ... Thought that would had been a bit much for my truck ...
Next part on the list to get for doing this conversion was a firewall mounting plate ..
That was super easy to do being "StreetRays" already was making one .. Just had to lay down a bit of green and wait for the 'Oops' truck ..
Ordered it to fit the 75 K15 truck ..
Being i have the K15 oem vacuum booster already on the truck was a simple thing to do ..
A little more work was needed on the firewall to allow the StreetRays plate to sit flush and since the vacuum booster is going Bye-Bye there is no need for the top two holes that the K15 booster used ..
Be welding those bad boys up ...
Another part that i felt i needed was a way to control the rear brake line pressure ..
Plumbed in a Wilwood adjustable valve to handle that job ..
Encounter another problem that stuck it's ugly head up while I was test fitting ... The brake pedal apply pin was causing a bind on the pushrod ..
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Had to relocate the pin further up on the brake pedal arm bout 3/4" ..
That move netted a fairy straight shot into the M/C ..
Making the pushrod was a bit of a chore to do ...
One side is 1/2" X 20T and the other side needed to be 3/8" X 24T ..
Made it from a grade 8 bolt ..
I'm petty sure that converting over to hydroboost would have been a plug & play deal if I wasn't dealing with a Frankenstein ...
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Another piece of the puzzle showed up today ( So says tracking ), there are 2 plastic bushings on the pedal's pivot bolt that showed signs of ware & tear. ...
I ordered new replacements for the 51 year old worn plastic parts ..
Jeremy89
