YakkoWarner
- May 29, 2024
- Central Texas
- Wolf
- R2500 Suburban
You got Windows 10 to talk to the OBD1? I can not get WindALDL to communicate using windows 10
I'm using TunerPro RT because I was told getting WinALDL to work on Win10 was hit or miss. If you have the Moates cable you need to use the
FTDI driver for it.
I've monitored and logged the data stream on 10-15 minute drives and the TPS doesn't seem to have any odd or stray jumps. With pedal full up it is between 0.45 and 0.47. Watching the data clearly shows the IAC opening and closing to maintain a ~1000 RPM idle. I did the IAC reset procedure where you let it fully close with A-B jumpered, disconnect to keep it closed and set the base idle with the set screw - with the IAC fully closed I could get the idle down to around 250 RPM without stalling, any lower and the engine would starve out (which to me indicates there is no vacuum leak since the buterflies could close enough to kill the engine, and the IAC is closing all the way otherwise the bypass air would keep the engine running).
Coolant, MAP, TPS all seem to be in believable values, and it does go into closed loop according to the ALDL data.
I have the 7747 computer, but I think you have to remove the chip and use a reader of some sort to actually extract the bin programming from the chip, I didn't see any way to read it through the ALDL connection. And I don't have a chip reader or burner.
