Air helper bags for towing
pmehringer001
Indiana
Paxton
V20
Not exactly a squarebody, but wasn’t sure where else to find this information. I have a ‘58 gmc 350. Have a semi 5th wheel on the back, nothing else. Leafs are extremely stiff when driving empty, haven’t had a load on it yet. I’ve found the leafs are 52 inches long x 2.5 inches wide. Same as 1/2 and some 3/4 ton squarebodies correct? I was thinking about putting 3/4 ton squarebody leafs on it with air helper bags. So it is bearable to drive empty, but can air up to stiffen up a little with a load. Seems that most of the bags I find are 5,000 lbs. just curious what exactly this means and would that be enough? With a gooseneck would it exceed 5,000 lbs tongue weight with a decently loaded trailer? Truck has a maximum gross combination weight of 32,000 lbs (would definitely not get close to that though) I would guess the truck itself weighs around 6,000-6,500 lbs, but not sure. First time doing anything with bags so I’m not all that knowledgeable about them. Thanks
Bennyt
Surprise
Ben
I'd look at Sulastic shackles and timbren bags as additional options.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I have the Ride-Rite helpers on my burb, along with an ARB pump. I can't comment on whether or not they would work for your needs, but they have allowed me to carry 3500# loads with ease. I installed the bags around 2005 and they still work fine. I did go through a few cheap air pumps before the ARB, trying to avoid the higher price, but you can't cut corners on that. When not loaded, I run just a few psi to get rid of the Suburban squat. I have no complaints and consider the helper components money well spent.
I would probably look at Firestone bags that they make for duallies and heavy hauling. I run AirLift helpers on all my half tons but they won't be enough for what you're doing
Braedyn869
