A-pillar grab handles.
SquareRoot
So my wife always complains about not having anything to grab onto when getting into my K20. I have searched to no avail for a solution that was easy to install. There simply isn't any solutions for the squarebodies that I could find.
So- I made my own. I will state upfront that I own a tubing bender, nutsert kit, mig welder and tap/die set.
I used some 1 inch, .095 tubing and two be 5/16 course thread nutserts per side.
I had to make a "boss" out of 1/4 steel with a 5/16 hole that I tapped with threads. The A-pillar metal is at an odd angle to the window glass and the pillar isn't deep enough for a nutsert.
I put a slight bend in the upper end to follow the contour of the roof.
I found some nickel plated 3/4 plugs at the hardware store that finished the ends off nicely.
Hopefully the pics tell the story. The handle is super solid and functional. Two bolts and it's installed. I placed it so that it virtually disappears behind the A-pillar from the driver/passenger perspective.
My wife loves it's utility but commented that it looked a little "homemade".
Well, I happen to like them. They are simple, effective and cheap.
Hotrodspdx
Hillsboro
scott
K5 Blazer
Great idea !! I think I'm gonna make one for the wife also :)
Big Chip
Michigan
Kevin
C35
I don’t think those handles look bad at all but I’ve discovered a little different solution. I find that a well placed finger gets them into the truck very quickly and if the finger trick doesn’t work the argument that ensues eliminates the trip.
eskimomann209
Modesto
Marcus
Women... all that effort to help them and they criticize. The handle isn’t the problem. The women are. (Jk but seriously) It’s a good looking handle! Is it capped on the top? If not I’d cap it
SquareRoot
Capped! Flush mounted nickel plated brass plugs.
eskimomann209
Modesto
Marcus
That’s what I thought I seen. Good looking. Haven’t seen caps like that
78C10BigTen
pennsylvannia
C10 BIG TEN
Lokar shifter? Or 465?
84-C20
Chevrolet
With the Stay at home order extended for a month here I'm going to make a similar set tomorrow, but there will be a few differences. #1. I don't own a tubing bender #2. I'm going to use stuff I have on hand and avoid buying anything. Most of what I have hanging around is 3/4" tubing so I'll go with that and post an update with pics once I get going on it.
samelthecamel19
