84 C-10 lowering
kenswim
Pittsburgh
Ken
C 10
Hello all, looking for some help with lower my 84 c-10 rear end, the front I pan on replacing the spindles. I would like to keep the same stock spring mounts rear since they are riveted on and I have the frame ready to paint. What is the best option when I plan on replacing all the other stock parts if needed (leaves, shackles etc.) thanks for the advice in advance.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
If you want the stock shackles and springs, I would probably suggest a flip kit.
J Knight
Baytown TX
82 Chevy
350ci
We really need to know how low in the front you are going and if you want it to sit level or retain the factory 2in "rake" after lowering.
kenswim
Pittsburgh
Ken
C 10
J Knight thanks for the help. Looking for the level look and not real low. I like the stance of the truck in your profile picture. I am hoping to keep the stock frame brackets. I am ready to paint the frame but I would rather switch these out now if needed. thanks for the advice in advance Ken
J Knight
Baytown TX
82 Chevy
350ci
I think your best bet would be a 3.5/5in drop. This will consist of 2.5in drop spindles, 1in drop coil springs, and a flip kit for the rear. Fwiw...mine is 4.5/8in drop but that might be lower than what you want.
kenswim
Pittsburgh
Ken
C 10
Knight thanks, what do you feel the best source is for the flip kit and instructions on how to do it. thanks
J Knight
Baytown TX
82 Chevy
350ci
Western Chassis or Belltech.
If a person just wants to drop the front the 2.5" would they need a spring too or just the spindle? I'm on the Western Chassis website and I'm seeing a 2.5" drop spindle and also a 1,2 or 3 inch drop spring.
animal
Lee
c10 silverado
350ish
You could just do the 2.5 dropped spindle.
J Knight
Baytown TX
82 Chevy
350ci
You just need the spindle to drop it 2.5in. If you put a drop spring with a spindle it will add to the overall drop. A 2.5in spindle and a 2in drop spring will yield a total drop of 4.5in from stock height.
Thanks, fellas. I think I'm finally going to get serious about dropping the stance on the '77 :)
J Knight
Baytown TX
82 Chevy
350ci
How low do you want to go...my guess would be 2.4/4in.
Yeah, something mild in the 2/4 neighborhood. Obviously, in this case it'd be 2.5/4 lol
J Knight
Baytown TX
82 Chevy
350ci
If you want to save a little coin....cut one round off the stock coils for 2in in the front and get a set of 4in drop hangers and shackles for the rear.
Does cutting the coil off the spring negatively impact ride quality or put the ball joints at a compromising angle?
johara
