'81 K30 4X4, 454 Exhaust Manifolds....time for headers ?
Finkaire
Finkaire
California
Loren
Silverado c10
Happy Sunday!
Headers are a PITA, they are noisy, they leak and the thought of possibly end-wrenching the plugs out of that big-block. I like the OE look under the hood as well. My 2-bits
dragstews
GMC-IH
Belleview Florida US of A
Body 1954, frame 1975
R-100
406 ci SBC
Lots of good info on this thread ...
Just ordered a set of Flowtech long tube for a 62 C-10 truck ..
They are not made to fit the 62 truck, made for later models (67-up)
The Oem crossmember has been removed, a four speed is going in ..
Which will require a new crossmember mounted further back in the frame ..
Tejas SteelWorks
Hoping the headers will be a Plug & Play deal ??
xm20k
Girard, Ohio
Big block long tube headers for a 68-74 Nova are the best fitting when it comes to square bodies, they point straight back vs most headers for a square that point weirdly on the driver side and makes making up an exhaust system a bit of a pain. They sit higher up in the frame rails and still clear the transmission including clutch linkage and won't drag on a lowered truck.
Nodakr68
South Dakota
Clay
K30 Scottsdale Dually
I have used, and currently use Hedman 69110 headers on my '78 K-10 BBC. These are for manual or automatic transmission equipped trucks.
OK, so something I have never thought about.....mainly cause I have no clue.....but my heads and cast exhaust manifolds had square ports. So does that now mean I can only use headers with square holes, or are the round ones able to work also ??
Like I've mentioned, I am a 2-stroke guy by nature and matching ports and surfaces with a little grinding and polishing, was paramount for added performance.....hence, why I ask, because I have never piped (headers) a 4-stroke before, LOL
Nodakr68
South Dakota
Clay
Tejas SteelWorks
That cross member is awesome, and thanks for the great photos and info !!
Moderator
Nope, round ports are fine. Just make sure the gaskets you choose are sized for good sealing. Which by the way, I much prefer the soft aluminum type. You'll never have issues with them.
dragstews
GMC-IH
R-100
406 ci SBC
That cross member is awesome .
I'm using one on a 75 K15 ..
Swap transmissions caused the need for it.
Went from a TH 400 to a 4L85E ..
Had to modify it some to fit what I had going on ..
Narrow it an inch at the trans mount ..
Super well made .. Very pleased with the quality ..
xm20k
Girard, Ohio
Interesting did the trans require it to be mounted from underneath? Mine sits the other direction and on top of the lower lip of the frame.
Just realized your trans might be too wide to sit in between the two humps were as mine has a ton of room because Powerglide.
dragstews
GMC-IH
R-100
406 ci SBC
I'm dealing with a highly modified 75 GMC 1/2 ton short bed 4X4 that's been lifted 4" ..
I lower the trans 2" in the frame to help the driveshaft out ..
The reason for modifying the crossmember was because of how I married the 203NP transfer case to the 4L85E trans ...
Didn't have alot of room between them ..
This old truck has been pieced together like Frankly was ...
jw23655
