5.7--350 Over-Heat??
Durfman77
Michigan
Charles
GMC
Well I did a stupid yesterday,, My ele fan works great and I have it so it can come on & off automatic [with sensor] or turn it on or off with switch,, So was about 50 degrees out I stopped to talk to a friend and forgot to put fan on?? Came out Gauge was in the red 260*--turn fan on cooled down in few minutes did I do damage at all???
Have Schaeffer 5w-40 oil in it Full synthetic, Seems to be ok just worried now? Has 116,000 miles on it.
at 260, leaving it on BUT cooling it down.. you probably saved it. my v6 from late 90s sedans start automatic procedures to prevent engine damage at those temps and one of them is aluminum and the other is cast iron. id imagine a v8 with full synthetic, heavier, and low mileage(rebuild?), id say you are probably okay. definitely steamy, but probably okay.
Its kinda cool, the one engine will shut down 4 cylinders and use them to pump air (no ignition or fuel delivered) to help cool the engine and it will alternate which 4 cylinders keep operating to keep it running to cool the bank. makes sense when you think about it. and when moving, cylinders turning slowly and without any combustion cant be making that much heat, but would be pulling in impressive amounts of air, which would really bring those temps down
Durfman77
Michigan
Charles
GMC
Thanks for message---I drove it today seems ok???--- Your engine with that cool down and shutting off some cylinders sounds like good idea?---someone was thinking when coming up with that,,
If you didn't blow the headgasket it's probably fine. Check your oil after driving it a bit. I'd also change the oil as soon as possible. Overheating the oil will cause it to break down faster.. even 10 degrees can make a big difference, although synthetic can handle it much better.
WFO
Texas Panhandle
I'll tell you the same thing I tell everyone, especially my Nephew, when they come into the house, and I hear their truck running in the driveway.
Do you have a bad battery, or are you just trying to seat the valves?
especially if it overheats for a long time change the oil. the engines i spoke of frantically say change oil after said event because the oil takes on the job of cooling MUCH more in this process
dbarham78
