silverscottsk10
- May 8, 2013
- trafalgar indiana
- mike
- k10
So I would like to build a 383
Be the first engine I have actually built rather than rebuilt with all stock parts
I know it's a 350 bored .30 over
A 400 crank and either the 400 or 350 rods can be used and one needs the bottom end machined to fit the caps along with the counterweights
Other than that I'm not sure what cam size, pushrod length, spring tension, lifters, pistons, rockers, or oil pump to use
I'm in school so this won't be an overnight project
My truck has seized piston rings in cylinder 7 so I plan to use this as a daily driver engine and occasional highway use for at least 4 hours straight between home and school
If you guys could help me out it'd be awesome
It doesn't need to be over the top by any means
But a roast of tires would be nice instead of 0-60 in 15 minutes
