1990 K5, Runs terrible: Need help
nhoffman94
Chicago, Il
Nate
K5 Blazer
Has a brand new filter. Double checked fuel pressure today, and its about 7 psi max so i will be buying a new fuel pump tonight, only 30 bucks new with a warranty from rock auto. Will be a pain to fix, but still worth it.
Moderator Administrator
You're on the right track. :waytogo: 7lbs isn't enough fp to open up even a TBI injector. Not with a good spray pattern anyway. Gas is probably just dribbling out of one injector. :shitsweak:
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
TBI fuel pump replacement........sounds like good thread! Take pics!
nhoffman94
Chicago, Il
Nate
K5 Blazer
Ok, so when i pulled the fuel pump i found the problem. The little rubber hose that connects the actual pump to the sending unit was completely disintigrated and had a large hole in it, when removing it, it was very moldable, like clay. Replaced that with some fuel line and two hose clamps and she runs better than ever before. Such a headache for such a simple fix. And after dealing with some tire woes the beast is back on the road again.
That's great to hear man. :grd:
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Man, had I gone through all that, I probably would have changed the pump while I was in there. Just my 2 cents. The main thing is that the problem is solved and she's back on the road again! :waytogo:
Awesome !!! Thanks for the update.
nhoffman94
Chicago, Il
Nate
K5 Blazer
Would have replaced it then and there, but i didnt have a strainer for the bosch pump or the correct wiring. if the pump goes out i will just open the floor back up and take care of it.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
no pics of the repair, huh?
Original
