Truck starts when motor is cool, when warm it’s hit or miss.
mk7_tristan
Missouri
Tristan
Have had this problem with the truck for about a year and a half now. Truck will start everytime when the motor is cold. Drive it to work, it sits for 8 hours and it’ll start back up perfect. If I stop and need it to start back up (like at a gas station or store) it typically wont start. The only thing that sometimes gets it to work is if I crank the steering wheel one way or another it will start to turnover and fire up.
Lights come on, doesn’t try to turn over when warm, doesn’t click. Replaced neutral safety switch in January and thought it fixed the issue until it left me stranded again.
Any ideas would be appreciated.
Sad Sack
Nebraska
Goober
C15
Tapping the starter case while someone turn the ignition key to start. And if HEI try another ignition module. Just throwing this out there.
77Dmax
vt
Joe
You might start with year/make/model/engine...
mk7_tristan
Missouri
Tristan
It’s an ‘87 V10 350 factory fuel injection still on. Tapping on starter hasn’t worked in the past, only way to get it started before it cools off is by moving steering wheel to either side and holding. Went out and checked connections again and they all look good. I had read that old battery terminals can corrode internally. I wouldn’t think the motor being hot would impact the terminals though.
Sad Sack
Nebraska
Goober
C15
With the info provided and the steering wheel allowing you to start may indicate an internal issue in the steering column such as the ignition switch but with info provided one finds this: https://share.google/aimode/P9lmSYPn0UCKKuWcm
Dale A
Bremerton Wa
Dale
R 3500
Had similar problem. check the coil, when cold the windings are making contact when it gets hot it expands and something inside breaks electrically, no spark. Cools down after several hours makes contact again. Installed a new coil and that fixed it
JIMYB
