1987 Chevrolet 350 tbi high idle
iamtherealJayy
Tennessee
V20, K10, K10
Nevermind it doesn’t work either smh I’m going to replace the 9v battery connector since I have some laying around and try again later.
Rusty Nail
Rusty
350sbc
If youre sure its at 8 thats no problem- didjya check it at least or are you takin that dude's word for it?
iamtherealJayy
Tennessee
V20, K10, K10
I never personally checked it but I watched him do it since he was explaining how to do it. So yes I took his word for it. I can check it today tho when it warms up some outside. Should I get it closer to 0°? Or is it fine at 8? Someone’s saying 0 youre saying 8 is fine. When I’d looked it up I believe it said 4-12 is factory but factory was 30 years ago
gmbellew
Kansas city
glen
suburban 1500
factory is 0 for your engine. some folks run a little advanced because they think it helps with power. too much advance will have the knock sensor retarding timing. 8 seems a little advanced to me. I'd probably run no more than 4 btdc if I was going to run advanced. I try to keep mine oscillating at the low point of 0 and high point around 1 or 2 when I have set it. once it is set right, you should be good for a long while...
Rusty Nail
Rusty
350sbc
Factory IS 0 for your engine he's right. ^^
The TBI in my 88 Blazer is set at 10° I assure you but all that matters here is that you take his word for it and we assume it is still set were he left it. 8° dont make em run hot.
:nono:
Where were we Jay - whatcha gonna do to it today?
:popcorn:
iamtherealJayy
Tennessee
V20, K10, K10
I’ll do it once I can find that plug you said to unplug… I still have no found it nor a tan wire. What is the wire coming from? These are photos of all the plug near and around the firewall/distributor area.
gmbellew
Kansas city
glen
suburban 1500
I just checked my engine operation. I hit closed loop at 140deg coolant temp. this came up earlier, so i thought I would update
iamtherealJayy
Tennessee
V20, K10, K10
@gmbellew can you provide more information of this plug in looking for? Perhaps a photo of its location?
gmbellew
Kansas city
glen
suburban 1500
could be a little different on your 87, but it is in the middle of both of these photos on my 90. taped to the main wire loom.
iamtherealJayy
Tennessee
V20, K10, K10
Just found two plugs on base of distributor. One is two wires pink and white? And goes up to ignition module I believe. And the other appears to be 4 wires
iamtherealJayy
Tennessee
V20, K10, K10
Bazinga! Under the clutch master cylinder.
iamtherealJayy
Tennessee
V20, K10, K10
Alrigjt my lunch break is way past being over, I’m going back to work but I’ll get started on timing when I get home n
:nono:
:popcorn:
Quit confusing him. The issue isn't that it was at 8BTDC when the guy checked it. The issue is that the guy checked it(and maybe moved it) without the ESC being disabled. There is no telling where the MECHANICAL advance is set at. The Mechanical advance should be set at 0, the ECM will then adjust the timing to where it needs to be.
You cant get the thing running right as it is, so don't try getting fancy and making "performance" changes outside the scope of the published procedure.
My guess is that the IAC valve is totally ***** and that is your problem. I would still check the timing though, because that will definitely cause some drivability issues and you have no idea what anyone might have done to the truck previously. Your pic of the connector looks like it hasn't been touched in a VERY long time.
iamtherealJayy
Tennessee
V20, K10, K10
I’m going to order a new iac valve from parts geek, Delphi brand. I doubt a lot of it has been touch although there are many connectors with nothing plugged in. Are those just plugs from the harness that would be used if I had more options? Truck is as basic as it gets. Custom deluxe.
sirex
