16" wheels on 3/4 ton v20 axles?
Willis
Seattle
Willis
V20
5.7L
Hello!
I'm trying to rid of the 16.5 wheels that are a hassle to find tires for. I dont want to go to a 17" wheel. Will 16"s fit and clear everything?
Thanks everyone for any help!
- Willis
CSFJ
Did someone replace your wheels with older ones? I though by 87 all the 3/4 tons had 16" wheels.
Green79Scottsdale
G.R. - MI
Bob
They "should" clear. My '79 K20 came with 16's stock.
CSFJ
I just double checked my '87 3/4 ton, factory rims were 16". the set of steelies I grabbed from a '90ish 'burban were 16" too. somebody must have swapped yours out over the years. The other thing to watch out for, unless I'm mistaken, I think the 16.5" were the old style split rims?
Moderator
They were not split rims, just regular 'ol 16.5's without a safety bead to help retain the tire. It was for easier service in the field.
I don't think the dangerous type of split rims have been around for 40 years or better.
CSFJ
Yeah, I couldn't recall the specifics on the split rims. Heck, I can't even remember the last time I saw a set.
MadOgre
NA
NA
NA
NA
NA
What are we talking about? Dayton wheels ?
Moderator
The old "widow maker" split rims. There was a certain design of locking ring that was known to blow off the rim if there was any rust buildup or if they were improperly installed.
Willis
Seattle
Willis
V20
5.7L
thanks guys, i know these are after market wheels. look like American racing wagon wheels in chrome. Also this truck has Warn front locking hubs.. are these any good?
CSFJ
Yep. Warn makes a good hub.
MadOgre
NA
NA
NA
NA
NA
Yep that would be a Dayton rim! I didn't know they were ever made small enough for a pick up.
Moderator
I always thought the Dayton rims were the ones with the giant 5 or 6 spoke hub and the rim is held to the hub with studs/nuts and little wedges. The rim itself is one piece though, the tire gets put on like any other regular rim.
MadOgre
NA
NA
NA
NA
NA
Ya, What are you guys talking about?
MadOgre
NA
NA
NA
NA
NA
A Dayton is a "widow maker"
Scrambler-Cafe
