14 bolt brake cleanup
BryanS
Ft Pierce FL
Bryan
Blazer K5
Hi everyone. I’m cleaning up a 14 bolt rear to swap into my k5.
Removed perch’s, old lines. Going to replace e brakes, adjusters wheel cylinders and hardware.
The shoes look good to me
I want to clean out the inside of the drum and backing plate. Dont want to go nuts just knock out the rust and maybe paint a little.
Should I use caliper paint or can I get away with just rustolium?
What are the pros/cons of using braided line vs hard line?
ASPEC
C2500
Remove everything. Use a wire wheel on the backing plate, paint it with whatever engine enamel your local stores sell (I like Duplicolor low gloss black).
You can save the E-brake lever, the adjuster assemblies and the spreader bar, wire wheel those and leave un-painted. get some hi-temp brake lube and grease the adjusters on the inside. Replace the wheel cylinders and all the hardware. Wire wheel the drums inside and out then paint the outside only. Grease your backing plate on the contact patches with the hi-temp brake lube. I would replace the shoes.
Before and after....
legopnuematic
Licensed Junk Dealer
MO
Spencer
And take pictures before you tear down each side to reference later.
And don’t throw any old parts away until you complete the job, not all hardware is available new and then the pain and agony of finding another whatever you threw out begins. DAMHIK and BTDT
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
^^^ TRUTH!^^^
evren
San Diego
evren
c30 Cab and Chassis
I just did this last year on a 73 C30. I had a lot of trouble finding some of the parts, there are 2 sizes of adjusters, the spring that goes on the adjuster bar (not the one that goes against the shoe but the one that is just on the adjust bar itself) and the pegs that go into the cylinder are super hard to find. Even the drums, orielly sold a set that was just a tiny bit smaller (~3/8") in diameter than the ones that Napa had.
So definitely follow the advice above to not throw anything out until you're done.
I had to go to all 3 parts stores in my area (orielly, Napa and parts authority). Each one had a different part that they could find. The issue may have been because it was a C30 and may be a frakentruck but I'm happy to share the part numbers I used if you need them for anything.
ASPEC
C2500
looks like it has already been in Hawaii.
If I had to guess, that axle has backed more than one boat down into some salt water...
molus
new zealand
morgan
k20
I went the strip down, sandblast and paint. New shoes, new pistons.
is that permatex purple ceramic? If so ,i advise that product specifically because of its qualities , esp where the pads that the shoes glide on
This is an example of me doing the painting thing, because the backing plates on these drums were pitted badly and i should have built them up with epoxy first then sanded flat then paint
OP what year is the 14 bolt from? How wide are the shoes? Im using a 1988 V20 as a source since you have slip on drums
Oliver90_08
