Whine after torque converter install
JohnMark
MS
1985 Chevy c10. 350 engine with th350c transmission.
I installed a torque converter on my th350c transmission. Install went well and everything bolted up fine. 3/16” gap between tc and flexplate before bolting up and the tc spun freely before bolting up. Filled up trans fluid after install and it was doing fine without noise. I drove it around the block a few times and pulled back in the driveway and this whine has been going on ever since. It happens in neutral/park and in gear. Double checked fluid level and it is good. Where do I go from here?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Ouch! Sounds like flex plate is rubbing. Perhaps forgot to torque down one bolt? Pull the inspection pan off and take a look.
JohnMark
MS
I will for sure check it this afternoon. Sounds more like rubbing than something with my pump? I have no experience with transmissions.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Ok good luck and get back to us. Also check your starter engagement and if the bolts are tight. Something moved after you drove it, so I suspect something... moved!
TubeTruck
East TN
Denis
Suburban K10
LQ9
Sounds like the pump to me. Let's hope it's not! Did you fill up the torque converter before you installed it?
JohnMark
MS
Yes. Around 1qt. Then put around 6 more in before driving.
Sounded like a pump to me too... but like I said, I do not know much about transmissions.
Where do I go from here if my bolts are tight?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Making those tight bolts loose again.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
As in taking out the trans? :eek:
Get some more advice first! Second opinions...
You need another ear, hopefully from someone with experience..
78C10BigTen
pennsylvannia
C10 BIG TEN
Im gunna bet that it surely a rub somewhere!!
JohnMark
MS
Sooo here’s the update so far... I pulled the inspection cover and the tc bolts were tight. However, I used the wrong drill bit to measure the spacing and it is actually right over 1/4” ... maybe 1/32 or 1/64 over. I believe this is too much of a gap (any input on this?) I’m headed to the store soon to get some washers to make it 1/8”. Any input or ideas on this is appreciated.
78C10BigTen
pennsylvannia
C10 BIG TEN
So are you saying that you think the converter needs to go in to the pump more or out from it more? Ive never had a converter spacing issue in all the trans ive put in. I put the converter in and keep rotating it till it drops in 3 times then slide it out as far as it needs to meet the flex plate. Dont shoot me!! Maybe im wrong! :shrug:
JohnMark
MS
I’m saying it needs to go towards pump more when bolted up. Most places I’ve seen specify 1/16” to 3/16” gap with the standard being 1/8”.
You said earlier that you think it is a rub. Where and how would I check for this? We’re could it possibly be rubbing at?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Anything over 3/16” is said to be too far. Washers will take up the gap, but don’t take it all out. Don’t forget, you may need longer flexplate bolts. They may be M10 x 1.5 pitch, iirc. As much as they look like 3/8”. Your tc may be different.
QBuff02
Central IL
Quincy
what kind of torque converter did you install? el cheapo unit? One purchased used off a guy on facebook marketplace? A brand new high performance unit from a reputable vendor? Are you sure you got the right converter? have the right trans? You should only have 3/16"-1/4" gap before seating the converter with the bolts. Any more and you run the risk of running into problems. Just by the sound in the video it does mirror something rubbing rotationally. But it could also be the pump in the trans. If you have to it's not uncommon or out of line to use some washers between to "take up" the gap. With everything loose, re-seat the converter to the trans/pump, measure your gap, adjust accordingly and reinstall the bolts. See what happens.
tnahaus
