What size springs?
86scuburban
San Antonio
Nate
383TT
Bought a 1/2 ton suburban with a good size lift on it but it looks like the previous owners ran out of money when it came to putting new springs in the back. The truck has 10" blocks in the back and I am trying to do it the right way. I am replacing the blown up 10 bolt for a 14 BFF, at the same time I want to do a shackle flip but I am confused as to what size springs I need to get to replace the blocks.
Sometimes your the pigeon and sometimes your the statue!
8T6K5
AZ
L98 350 TPI
......looks like the previous owners ran out of money when it came to putting new springs in the back. The truck has 10" blocks in the back and I am trying to do it the right way.
:Whoa: :Whoa: :Whoa: :Whoa: :Whoa: :Whoa:
....I am trying to do it the right way. I am confused as to what size springs I need to get to replace the blocks.
To replace the blocks and maintain 10" of lift or are you unsure wether you need 52" - 56" springs? A 1/2T Burb should have 52".
You have to to post some pics of this rig, 10" blocks are absolutly insane!
As you said, PO did it so dont think Im slamming you, just have got to see this. Glad to hear you want to correct that problem.
86scuburban
San Antonio
Nate
383TT
Yes I want to replace the blocks and keep the 10" lift. But if I do the shackle flip that gives me 4 inches right there so do I only need 6" springs? I will get some pics of the crazy blocks this weekend. I drive it for a year with the blocks till I broke the 10 bolt.
86scuburban
San Antonio
Nate
383TT
Well that helps a ton. Thanks!!
8T6K5
AZ
L98 350 TPI
Shop around though, Ebay, CL is a good place as well. You might be able to find some of those parts slightly used.
I havent had a problem with their stuff, not promoting it, just presenting it as a reference.
86scuburban
San Antonio
Nate
383TT
Holy ****!!!!! :wtf:
elstm3
montana
lynn
V30 crew cab dually
6.2 twin turbo diesel
:mfr_omg:
Well, at least it's all one block. I've seen stacked 4 inch blocks before.
JoshinIT
