What should I do with this toolbox?
Camar068
Air Force Supporting Member
10 yrs Air Force
Solved:
I put magnetic strips from amaswan in the corners of the radiator support (underneath). Helps hold tools/nuts/bolts when your working in there.
84GMCSierra
Supporting Member Air Force
Central Arizona
C2500
I have a 3 drawer from Tractor supply that I keep the most important tools in when I go on long trips like when I go on the Rt 66 Fun Run in May. When I'm back everything goes back in my large rolling tool box
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
Make it a mobile tool chest by building a low platform beneath it and installing larger (6") swiveling pneumatic tires so you can roll it around your unpaved garage and or driveway to whatever you're working on. Keep a low center of gravity so it cannot tip, and you can probably sit on it when the lid is closed.
I like this idea.
MRmolash
