84GMCSierra
Supporting Member Air Force
Central Arizona
C2500
wish the running boards ran behind the rear tire.....be an awesome step to get into the truck. But I don't think they'd look right.
I don't think so either. I've seen a step that hooks over a tire, but haven't seen any reviews on them
hogdaddy
Alabama
mike
Scottsdale
I bought a full set of Bilstein shocks and got the front pair installed. The rear shocks will be installed tomorrow.
The ones I took off were shot and IIRC, those came from Autozone several years back. Pics will be added later.
The CSI water neck got a new set of O rings too.
PeteJr
NW MS
GMC Sierra Classic 1500
Finally got my new front coils, spindles, tie rod ends installed on the rebuilt control arms.
Cleaned up the inside of the front cap and did a little rust clean up and primered those spots.
Forgot to take a pic............
Next are the rotors and new calipers, hoses, seals etc.
DrvnDrvr
Central Oregon
Al
I have a hook over the tire step and it works great. Only thing is I'm sure one day I'll forget it's there, take off and crush it and possibly puncture the tire sidewall.
Muddybuddy
VA
James
I will have to get some pics later. It's dark now.
The Flowmasters sound good!
Still need tidy up a bit and install new gauge bezel and dash pad.
The new throttle assembly from Hotrod Innovations and Lokar cable rocks!
Are those speedhut gauges?
hogdaddy
Alabama
mike
Scottsdale
Indeed they are! I modified the stock pod and used metal instead of the plastic piece to hold the gauges after enlarging the holes. The new gauge bezel I am going to use was modified in back to sit flush like a stock unit.
The Speedhut gauges have a lower profile in the back which is nice and most wires daisy chain together.
Muddybuddy
VA
James
Can you share more details? What sizes? I had speedhut gauges in my old foxbody and loved them. Would consider them for my k5 as alternative to DD, but wasnt sure they could be fit into stock bezel cleanly
hogdaddy
Alabama
mike
Scottsdale
4" speedo and tach while smaller gauges are 2- 1/16.
It was not easy to do but I took my time fitting everything. They do not fit the holes without enlarging.
The hardest was cutting the new expensive gauge bezel in the back. I used several methods to shave off the back to sit flush. I even used a hand file over a period of many days.
ChuckN
Bellinham, WA
Chad
Which Flowmasters did you use? I really like my 40s.
tater dog
tater
k30
Put the finishing touches to the interior in the cargo area . Truck was bone stock with just a torn rubber mat . Got most of this free and dyed it all blue .
Moderator Administrator
Looks really nice!!
hogdaddy
Alabama
mike
Scottsdale
Which coils did you use and did you use coil spring compressor? Stock spindles or lowered?
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
SMOKE in the holes,, Good old BLACK diesel Smoke in all 4 holes Turned over about 4 times then fire in ALL 4 holes right now!! No banging away on 1 or 2 Was all 4 with black smoke. Hope to get it in the shop Fri..I love the smell of Diesel smoke
tater dog
tater
k30
I hate side post terminals with a passion . Plus it’s difficult to connect jumper cables to . Will be doing this to all side terminal vehicles I buy now
wshoneybadger
