Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
Took a load of scrap metal to the recycler, then came home and finished assembling the LMC tach kit. Need some more twist bulb sockets for the back, but went together without issue. Just wish LMC would include all of the necessary screws- was short a couple, even with reusing mine.
pretty simple and self explanatory? I plan on take this route on my project as well
Redfish
Prairieville, LA
Andrew
V1500
I very much want to do this as well. I like the idea of keeping a factory look but I always wished for a tachometer instead of that huge fuel gauge when I was driving my parents' vehicles. The nostalgia is nice but I want a tach.
Of course I am VERY proud of my Quartz Clock! I hate to lose that.
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
Go LED! So you never have to replace them!
ChuckN
Bellinham, WA
Chad
I don’t have it actually installed yet- still trying to find some twist light sockets locally today- but, I guess the answer to that depends on how familiar you are with the inner workings of these clusters. The LMC instructions aren’t terrible, but it’s helpful if you do one of two things:
1- take it apart and put it back together in the reverse order while it’s fresh in your brain or…
2- take some cell pictures as you go along in case you can’t remember the sequence, that way if you get interrupted, you can reference them. And which gauge went where in the side holes.
The gauges are only held in the backing plate by a handful of screws, and they are partially stabilized by the little spring clips that the posts slide through to make contact with the printed circuit. The new clips from LMC have new tension, so I found it helpful to put a flat blade screwdriver in the spring clips and spread to take some of the tension out so you don’t have to push on the gauges so hard to get the posts to slide through the clips during reassembly. Don’t go all Hulk on it, just enough to take a little tension out, like Bob Ross would do. It’ll keep you from having to push so hard on the gauges when you’re putting them back in the cluster.
Getting into the weeds a bit here, but I’d call it a 2/5 difficulty. Just be really careful with all the gauge needles. They are extremely delicate. I actually found a NOS AC Delco gear indicator on Ebay and was testing it lightly to see if the trolley slid freely and bumped the needle- snapped right off. But, I was able to use my broken-cable original by using the cable from the NOS and fixing it. Yes, they are that delicate.
Of note- MAKE SURE you order the right kit. LMC tach kits jump from pre-‘80 to ‘83 and up. The ‘83 and up uses a backing plate that is for electronic speedo and does not have a provision for the cable clip. If you have an ‘81-82 you can still use the kit, but you’ll have to order an additional backing plate that will have the speedometer cable clip. Which is what I had to do since I was unaware of that discrepancy. It would be interesting to add up all their parts on the website and see what the difference would be in price.
Hope this helps (probably not ;) )
ChuckN
Bellinham, WA
Chad
Lol good call. Hafta find some damn light sockets to put them in, tho- apparently my cluster was taken out of the truck at one point and put together with some of my light sockets missing.:wtf2:
Pulled it out into the sun yesterday to take pictures and video to send to the guys that did the liner. It looks fantastic, hopefully it'll be as durable as other liners.
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
Installed the relay that turns all 4 headlights to come on when you hit the brights for the 89 burb. It was simple and well worth it and highly recommend it if you have this front end. Replaced the headlights with the new ones from lmc. These are a great upgrade that I again recommend for ysll with this setup. The screws that hold the lights in had to be replaced with new sheet metal screws because they'd rusted up. Got them at TSC. Put a little grease on them and screwed them in. I'm super happy with this upgrade. It was simple and everything fit perfectly. It cost me about 200 bucks for the new lights and the relay for the 4 lights on high.
TheBlazerBeam
Washington
Blaze
K5 Blazer
350 V8
I don’t know if y’all have heard of this, but I installed the Wolff Engineering steering column bearing and it tightened up my steering a ton…and then on the way back from my test drive the truck died as I pulled into the driveway. Definitely worse places to break down
Redfish
Prairieville, LA
Andrew
V1500
I pulled a 4 wheeler around behind mine. Then we shined it up and I took my roommates out to dinner.
The Right side of Washington
I replaced both front calipers with a remanufactured set. The truck drives soooo much better. Apparently both calipers have been performing erratically for some time making me think I had more slack in the steering than I really had. They were original to the truck from 1987. They only had 62,900ish miles on them.
While I am completely satisfied with the brakes on this truck I am now thinking very hard about the Wilwood calipers as an upgrade. For now though, I am really happy with how much straighter this truck steers and stops.
And yes, if anyone is wondering I do Feel Stupid for thinking poor brake performance was steering slack. But the truck never did the same thing twice in a row so I truly thought I had something wrong in the steering. No wonder I never could get the d***ed steering wheel straight...
Thanks for posting this!
On one hand, the fact that the oe calipers were still calipering at all 36 years later is amazing.
On the other, probably overdue.
Makes me add this to the list as well.
I haven’t touched the steering yet on the 86 and have plans to adjust the steering box and some day remove the rag joint.
Truck generally goes in the right direction all the time on the road at any speed. But when applying brakes it does tend to hit a little more on one side or the other sometimes and requires a little steering attention. Even though cramming on the brakes on a flat road is dead straight, hands off the wheel, stops.
Ours might be getting a little sticky.
Looks great! Now I’d be afraid to scratch that stuff! Lol
So what’s the scoop on this stuff? More like Rhino or Linex? Did you shoot any scrap metal for some durability testing?
DIY kits forthcoming?
Redfish
Prairieville, LA
Andrew
V1500
So far today I have driven it to my favorite-ex-brother-in-law's so I could install a soft top on his roommate's Bronco. Last summer I installed the roll bar, I recently installed 3 point seat belts, and today we did the bikini top. I think it came out pretty nice.
82sbshortbed
Why like that?
SE Texas
Doug
My new running lights and blinkers housings for the front came in today from Amazon. These are nice oem parts. I'd recommend getting these for yours. My old ones were trashed so got these. Wired in new running light socket too. So now all my front lights are brand new. Here's the link.
CarLights360 For 1989-1991 Chevy Blazer Pair Park / Signal Lights Driver and Passenger Side Unitw/quad headlamps; park/signal combination GM2520130 GM2521130 - replaces 5975227 5975228 https://a.co/d/42sTYJL
Joestreml
