FireTruck1984
Michigan
1984 and 1984
Do you have a link for them?
[email protected]
"Tailgate hinge upgrade for Chevy/GM trucks"
TD Trunnion Design
"Helps prevent rust while reduces the noisy grind"
Silent 'gate as Classic truck magazine mentioned it in Feb 2016
HOME​
The Ultimate replacment Tailgate hinge for your Chevrolet/GMC Stepside, Fleetside, Jimmy, & Blazer trucks. "Patent pending"
Made in USA!
Available Now!
  • 54-87 Chevy/GMC Stepside truck - SOLD OUT
  • 58-66 Chevy/GMC Fleetside truck
  • 67-72 Chevy/GMC Fleetside truck, Jimmy & Blazer's
  • 73-74 Chevy/GMC Fleetside truck
  • 75-80 Chevy/GMC Fleetside truck set Removable
  • 75-80 Chevy/GMC Fleetside truck set Non-removalable
  • 81-91 Chevy/GMC Fleetside truck set Removable
  • 81-91 Chevy/GMC Fleetside truck set Non-removalable
S
PeteJr
NW MS
GMC Sierra Classic 1500
Don’t forget the roof/ceiling before the headliner goes in
Gotcha covered, Ted (and the ceiling too)
I have enough left to get a couple pieces in each door.............
FireTruck1984
Michigan
1984 and 1984
You’re gonna love how quiet your interior will be.. and a satisfying crisp and solid sound when you close the doors.. the KilMat makes a huge difference.
ive never owned truck with a headliner period, i bet anything would be a improvement for the drone i bet that small flexing roof tin can etc
PeteJr
NW MS
And the price is so much less than Dynamat or some of the other "name" products.
FireTruck1984
Michigan
1984 and 1984
Noico brand is even less expensive.. their 80 mil is the same quality as the others. Just doesn’t have the brand name on it.
Camar068
Air Force Supporting Member
10 yrs Air Force
Took off fast today leaving the sub-division and it didn't like shifting into 3rd. Did what short running I needed to do in town, but if I was in the throttle above cruising it didn't like the 2-3 shift.
Long story short, one of the hoses I put in place during the LS swap was leaking/spraying. Took me an hour and 3 parts houses to figure out that 11/32" hose is power steering hose. Got it fixed, but will likely drop it off somewhere for them to run solid lines. Should be able to get it done for $100 here locally with me providing the line.
gmbellew
Kansas city
glen
suburban 1500
i was having occassional and random high idle on the 350 TBI. according to ALDLDROID the IAC valve was getting stuck in random positions even though it was only 3 yrs old. So I replaced it with a delphi and am hoping for longer life. I also replaced the multifunction switch so the cruise would stop kicking off when I turned on the wipers. it took me a while to do the switch because I convinced myself it was a safety feature to prevent the cruise from use during the rain :)
PeteJr
NW MS
Today:
Put the new door seals in.
Put the old headliner back in................. a little bit of a challenge by one's self. Cleaned it, looks better outside the cab
Added some of the newly painted trim parts.
Cleaned, painted and reinstalled the rear speaker brackets & speakers.
(I'll have to take them out again when I decide what I'll cover the insulation with, the cardboard tray was a mess)
wshoneybadger
