ajd89
Central Michigan
andrew
Got my trans out and tore down. A bit of issues. Hard to see but the drum is wore pretty bad seems the last guy didnt get the seals in right.
Poppy 87
Bloomingdale GA
R10 Silverado
It appears to me that the end play may be the culprit. Inspect the case very closely
Sent from my XT1254 using Tapatalk
ajd89
Central Michigan
andrew
Intresting never thought of that. Makes sense. Anywhere special to look at the case?
Also broke a wave plate and the pump bearing (think thats what youd call it) is tore up.
This is the first time ive pulled a transmission apart. My father in law used to build them at work so he will help me get it back together.
Big Chip
Michigan
Kevin
C35
Man! You are just not having much luck with that truck, are you?
Big Chip
Michigan
Kevin
C35
Haha Nope. Would have been simpler to do this a month ago when I put the engine in huh?
I suppose if you were a witch and could see the future you would have done just that.
Poppy 87
Bloomingdale GA
R10 Silverado
Yes, look at the very bottom/rear where the thrust washer is installed. This is where the rear end play is established. The front end play uses a selective thrust washer on the rear of the pump body
Big Chip
Michigan
Kevin
C35
Changed my thermostat to a 180°. It was pretty cruddy and for some reason the thermostat was bent.
Poppy 87
Bloomingdale GA
R10 Silverado
By the looks, appears previous attempt to install was forced as indicated by the bent cage. Probably didn't remove the hose from the t-stat housing
Big Chip
Michigan
Kevin
C35
Hard to say. It has 2 different length bolts and the there was so much shot on them you could only see the thread that were in the intake.
Poppy 87
Bloomingdale GA
R10 Silverado
Does loading parts for Ole Bessie into the POD container count as what I have done to my square lately? She is bedded down at our new place near Savannah in the garage! Trying to complete my move and get the **** out of Atlanta metro area
Poppy 87
Bloomingdale GA
R10 Silverado
Sorry Rusty, no pix, but will add when I get to my new place permanently
OldBlueDually
Minnesota
Justin
1976 GMC
C30
455 Olds
I did not take any pictures, I could though but man when a guy gets working and the phone is hooked to the stereo system in the shop, I just want to keep working!
Anyhow, finished interior welding this weekend. Applied two coats of rust converter on everything that had rust, and even put it over the new steel I have welded in as the converter also is a good priming surface.
Now at this point I have some white rustoleum paint leftover from something else, so I will cover up these rust surfaces with that for a bit more protection. Then it is on to insulating the floorboards and firewall.
Or I will install vent work first...either way it will get done.
Yesterday since the last coat of rust converter was curing and I wanted to keep working I was carefully pulling apart the 3" exhaust system (it has smitty mufflers on it....wonder what they sound like??) on it and did NOT have to cut any of it!! Then got shocks off and disconnected rear brake lines in preparation for the installation of the lowering kit.
I should take some pictures, reading all of my above words kind of sucks....
Scrambler-Cafe
