TubeTruck
East TN
Denis
Suburban K10
LQ9
pulled the front cover on the 60 to do a little inspection and put in some fresh oil, while it was draining I found a wire retainer off the back of a seal in the bottom of the diff and found there's just a touch of play in the pinion bearing so i'm assuming that's where it came from. Also looking like limited slip, locker or spool time will be coming!
ARB Air locker!
86suburban
usa
brandon
k10 suburban
I finally started driving mine last week after a year or so of doing way more than I planned to it. I washed it, and installed this crazy expensive cup holder.
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
I like the red and white! Looks good
82sbshortbed
Why like that?
SE Texas
Doug
Got the po drivers side wiper arm and new blade on for inspection.
I have 2 new arms with blades but, the old wiper knobs on the assembly are stripped of its teeth. Hence the screw in it to hold it on. I have new assembly too. Just wanna get it on the road as fast as I can.
jjester6000
Illinois
Jack
C1500
I just pulled the head off my engine, and I seem to have a slightly burnt valve.
Luckily, I have a whole new higher compression head (from a 194 i6) to swap on.
K201979
Winona, missouri
Hippie
350ci
Added a light up bow tie. Needed a new one, figured why not a modern one?
I made myself one, and i like it, but had i seen this first i mighta went that route.
Dutch Rutter
Independence, Or
Joshua
Put my summer boots on, they look small for the truck to me. Really need to wear through these quickly, as well as the MT winter set so I can justify new tires.
Marine Corps Moderator
Started taking the front end apart on my 82 Blazer to powder coat the spindels, and backing plates. Also cleaning up the frame preping it for painting.
Got to put my rear disc brake convertion on the Extracab, and put my new to me shoes on....
78C10BigTen
pennsylvannia
C10 BIG TEN
Got my air horn installed under the hood and working. Just need to tidy up wires and screw the button to the dash. I decided just to buy a button rather trying to chase horn wire. Kinda proud I figured out the wiring because I'm not too familiar with relays. One step closer to getting my safety inspection and get plates and tags.
What does that sound like?
78C10BigTen
pennsylvannia
C10 BIG TEN
I'm glad I'm not the only one that chooses not to deal with removing the extra crossmember bolts.
I took those upper supports off while doing trans swaps and also never put them back on! Lol that makes 3 of us
Poppy 87
Bloomingdale GA
R10 Silverado
What calipers are you using for the rear conversion?
Sent from my XT1254 using Tapatalk
78C10BigTen
pennsylvannia
C10 BIG TEN
Well this was actually last weekend but i been havin phone issues so i never got it posted. Started out by noticing no fuel in my filter with the truck runnin so i bought another fuel pump. I added a pressure gauge in line with my old pump and holy cow was it wildly erratic! So i commenced to putting on a new pump and inspecting the push rod. I messed up the plate gasket and didnt have another so i improvised! Got everythin all back together and it runs 9psi but still no fuel in the filter and seems to not pump it up there. Im lost because i drive it daily this way with no issue, hows that possible?!
78C10BigTen
pennsylvannia
C10 BIG TEN
Few more plus the video of the gauge.
mo4154
