CoggedBelt75
Oklahoma
Joe
Picked it up today after motor and transmission swap and new suspension done. It wasn't too bad driving home with open headers but, I wouldn't wanna do it all the time. Took a small video of the ride home. You can't hear it real good unless I step on it a little. As you know it's much louder taking off from a stop.
If it’s too loud, your old:)
Here's the new stance
Like it much better than before.
Sittin pretty
FireTruck1984
Michigan
1984 and 1984
Looks good, What are the sizes of your tires?
80BrownK10
Greenwood, SC
Nate
I also buffed the '88.
Not bad for a $300 truck.
No, no it's not! You don't find $300 trucks around here...not that I ever hear of unless you like know the person and they want to help you out or give you a deal.
80BrownK10
Greenwood, SC
Nate
I finished buffing my '74, and it came out pretty good.
Am I seeing double?? Haha this is literally almost the same post from yesterday?:33:
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
Also, with the 454 I can't use my fan shroud. I need a slimmer one now. Do y'all know if they make them?
The fan is a lot closer than before. I don't know if y'all can tell in the pic it's dark.
Do you think it would be hard to modify mine?
Really happy with the way it sits now.
Shorty81
Baby Boomer
North West ohio
Darren
X2. Looks awesome!!
Poppy 87
Bloomingdale GA
R10 Silverado
Never done a big block swap on a square, so I will yield to the experts amongst us, but have you ever considered an electric fan? That is what I would do
Sent from my XT1254 using Tapatalk
82sbshortbed
Why like that?
SE Texas
Doug
That did cross my mind. I'm gonna look into that. It ran about 185 on the way home and I sat at a couple of lights for a bit. I looked at temp gauge when I pulled in the driveway it was 185. It's about a 5 to 7 mile trip I'd guess. I got no plates or tags for it yet.
Turbo4whl
Downingtown, PA
Wayne
When I put the big block in my '82 I used the fan guard from the same year 250 inline 6 cylinder. Not really a shroud, just a top cover for the radiator. I still have the small block radiator installed. Probably will not work if you put in a larger radiator.
Moderator
When I swapped the big block into my '84, the previously swapped in fans from a Buick Rendezvous still worked great.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
78C10BigTen
pennsylvannia
C10 BIG TEN
Swapped in the new master cylinder and self bled the brakes with a Mt. Dew bottle. Worked awesome. Truck stops on a dime now. Got home then my phone started blowing up with msgs from FB marketplace. A couple hours later I toss a set of seats into my truck and head 6 miles down the road. The motor revs to the moon and won't shift, it does this sometimes when it's cold. I pull it down a gear and upshift and it slams into gear. I'm thinking "ok, it's low on fluid". I made my delivery while manually shifting the whole way but it won't go into 3rd. So I stop and grab a gallon, pull the dipstick and it breaks off in my hand. I was able to catch it before it went down the tube though. So now I have no idea how much is in the tranny. I just dump 2qts in and head home. Same thing won't shift. I pull over and dump in another quart, circle around a parking lot and same thing. Then it dons on me, the vacuum actuator on the transmission. I get under the truck and sure enough!
So now I start scrambling around the truck. I know I have hose in there somewhere. Found some that was a little too small for the actuator (why do they make the actuator nipple and the steel line different sizes? Stupid engineers) and it's 2ft long. Well since I broke my knife I didn't bring it with me but a plastic knife kinda works if you go real fast! Got it buttoned up and shifting right. Now I have to drain some fluid out of the tranny lol
Because Roadkill!
Redneck ingenuity. Hack at it a platic butter knife! :893Chainsaw-Smilie-:happy175: i had that happen to me, it would pop off at a mile or so every time. I custom zip tied it on lol
78C10BigTen
pennsylvannia
C10 BIG TEN
Great vid!!! Love it!! Why no pics of BBC?!
Huffer8
