Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Ummm, does the spare PMD have a resistor chip in it? Otherwise that might be a problem. Most people don't know about the calibration resistor and go swapping PMDs willy-nilly.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Not that i needed it but i thought id give the pex trick a try. Damn i didnt think it would work that well!
What exactly is PEX ? I have read about this trick and would like to try it.
78C10BigTen
pennsylvannia
C10 BIG TEN
Got to the harware store and look for shark bites in the plumbing section, itll be very close by. Ill post you a pic of it tomorrow.
MrMarty51
Eastern Montana
Martin
HA, I`ll have to take a look in the connector. I do have a spare no.9 in the tool box, I run a no.5 in My grey box Stanadyne that's mounted to the heat sink, behind the bumper.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
The resistor is matched to the pump's calibration, so unless the rebuilder was thoughtful enough to stamp the resistor number on the pump somewhere you're kind of SOL if the resistor is missing.
MrMarty51
Eastern Montana
Martin
The pump can be forced into relearn mode, KOEO, accel pedal to the floor for 45 seconds and engine temp over 170 or 175 degrees, I dont remember, then, key off for 30 seconds, then, start the engine, engine will run very rough and even to the point of dying, it is relearning timing too, restart the engine if it dies and then it will proceed through the learning curve and idle at a normal rate. It too will relearn after 50 key cycles, from what I have been told by those with much more experience in such matters. LOL
Scared the crap out of Me the first time I run through the relearn process, after installing new timing chain/sprocket components. Engine started running rough and died and I thought, oh S#*t. LOL
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Which has absolutely nothing to do with the calibration resistor. Sorry.
MrMarty51
Eastern Montana
Martin
Even after the 50 key cycles, from what I read is after so long, if a resistor is not installed, the pump will fail to function after a while, so, there must be a relearn process in there somewhere, I switched Mine to a no. 5 after removing a no. 9 and have not had a problem.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
The "relearn" process is to put the pump on a test bench and go through the calibration procedure. The test equipment will then assign a resistor number to install and then retest the pump to verify it. There's no procedure that can be done on the vehicle.
You can probably get away with substituting a resistor. Depending on the actual calibration vs. the resistor it may or may not be noticeable.
Poppy 87
Bloomingdale GA
R10 Silverado
This resistor stuff sounds like complicated nonsense...
Glad I like gassers, lol
Without the said "test equipment", probably similar to the hit or miss trial and error process of changing jets in the carburetor and timing the distributor
Sent from my XT1254 using Tapatalk
Moderator
Good point. But familiar things = easier things to me.
FireTruck1984
Michigan
1984 and 1984
Got rid of the ugly hex bolts that fasten the rally center caps, and added polished stainless button head machine bolts. Also have 5 per wheel (not 3).
A much cleaner look
crowe-t
