smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Still screwing with why my high speed won't work on my ac blower fan. Uuugh! At least this isnt my daily driver and it sits most of the time in the garage getting dusty.
I know what you mean Hotrod...damn near everything on my square is new or upgraded...and I STILL have had to swap out "new parts" due to them malfunctioning...especially electrical components like relays. I preach to my kids how crappy auto part quality is with "new parts". Hell, just last week I had to buy a new exterior door handle for my offroad Tacoma build. The new handle wasn't even out of the box 5 mins and I noticed that the metal mechanism was flawed and made from cheap thin gauge metal. I contacted the company, complained about the crap quality and they instantly gave me a full refund, told me not to return the part and to throw it away. WOW!!! I guess its not the first complaint and they obviously know its not made well....AND it was a genuine Toyota part...wtf!!
Stepside Billy
Lake Carmel, N.Y.
Billy
Put on a new caliper and pads. Did the driver side bearings because they didn't look too good.
CRM
Pasco, Washington
Casey
K2500
350 CI
New valve cover gasket, temperature sensor, steering wheel, side view and rear view mirrors, windshield, tilt back bench seat, wiper blades, fuel and air filter, clutch and break pedal rubbers, interior bulbs, sound system, tires, license plate lights, windshield washer rebuild kit, fuel system and coolant system flush. Also painted the valve cover, thermostat housing, and air cleaner cover. Next up is reupholstery of the seat and dash cover.
animal
Moderator
Lee
c10 silverado
350ish
I wish I had something to post in here. :bawl:
74 Shortbed
I just picked up a donor truck with a lot of new parts for the frame since mine is bent.
Camar068
Air Force Supporting Member
10 yrs Air Force
Have you looked at the auto-dim mirrors? Absolutely love mine. With it i'm getting much less reflection off the back glass. $40-50 on ebay. Probably less if you have a pick-n-pull close by. LOL I'd go nuts if I had one close by....kinda like that first trip you ever made to Harbor Freight lol.
bluex
Spartanburg SC
C15
Well I got nothing at all done last week, the week before that all I got done was the core support cleaned an a fresh coat of semi gloss black. Today I got the trans crossmember mounted up. Frame looks rough there now with holes for a th350, 700r4 an now the nv3500 lol.
Really hope I get to drive the thing at some point in 2016 lol.
Moderator Administrator
Have the '87 in the shop getting the AC back to 100%. front AC works but needs a charge and the small leak fixed wherever it's at. Also, getting the rear AC working again. I'm tired of having a HOT burby in these hot summer months.
Also been working this week on finishing off the audio portion of my '87 build with getting the panels wrapped in vinyl. Will post pics once 100% complete.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Would you believe I haven't touched the A/C on the Caprice since I bought it, and it still works great? Guess the Freon didn't like Missouri and tried to escape when it lived there! :D
:lol: Yeah, I'm surprised you haven't had to recharge it LOL She must like you a lot better than me :rofl:
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
You'll love having the front and rear a/c working again. I converted mine over to R134a after purchasing it in '04. With both blowers on low, it gets cold enough to almost be uncomfortable, even with outside temps in the 90's.
And what did I do today? Finally fixed the chirping/squealing serpentine belt. Discovered it was caused by me not installing the p/s pump pulley deep enough onto the p/s pump shaft. So that made the serp belt run at a slight angle, causing it to ride against the forward lip of the water pump pulley. Rented the tool from Autozone, pressed the pulley inward about another 3/16" and used a metal straight edge to check alignment to the crankshaft pulley....and voila' the squeal is gone. D'oh.
Not a thing [emoji22]
I have yet to get a rebuild kit for the 350....I miss my truck
Have you at least tore it down to mic everything so you know what kit to buy? You'll need to measure the cylinder wear to find out it it needs a bore, and if so how deep you have to cut it, or if you can get by with just a rering, I'd plan on boring though, so that means you'll need new oversize pistons too, .030, .040, or .060 over and rings to match. Plan on taking those to the machine shop to have the pistons and wrist pins pressed. Also, have the con rods reconned. Hot tanked, magnafluxed, shot peened, checked for twist and big end resized. Replace with moly con rod bolts and nuts if you intend high rpm.
Look for scores in the crank. If it has some and needs turned, then find out if it will clean up at .010, .020 or .030 on both the rods and mains so you can get bearing sizes to match. Hopefully it will just need a polish clean and not have to be cut, if it needs a cut, hope for .010/.010.
Then not a bad idea to have the complete rotating assembly balanced since the machine shop will have your crank, rods and pistons.
silverscottsk10
trafalgar indiana
mike
Not a thing, been waiting until I have the cash, it's a crate motor though and idk the miles, I've put 20k on it in 3 years, there's receipts on a rebuild a year before I got it, I'll mic it but I think I want to put a little bigger cam
No scores or anything past normal wear, everything looks good, couple cylinders had been ran lean but I won't be going back with edelbrock when it's finished
Looking at entire rebuild kits from summit that have everything except the block and crank
crowe-t
