flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
Ya don't forget the filler knecks attached to your tanks are also attached to your box!
What about lights? Maybe I need to crawl under and look. After I rebuild my carb this weekend in going to see about getting my drivers tank functional. Tank looks good from what I can see...
Sent from my SCH-I605 using Tapatalk
MadOgre
NA
NA
NA
NA
NA
Theres probably not a whole lot of room with the wiring either.
My drivers side is on my to do list as well.
flyboy1100
UsA
me
k1500
In hoping it is easy, like bad dash switch. The tank/filler/vent all look really good.
MadOgre
NA
NA
NA
NA
NA
I got to drop mine and clean it out then POR 15 the outside.
flyboy1100
UsA
me
k1500
I need to do the frame. Any idea how much is required?
MadOgre
NA
NA
NA
NA
NA
POR 15? 1 quart does one coat by brush on full frame and a little extra. Its always a good idea to prep as many parts as possible so that you maximize your can of POR 15.
Speakfordadead
Woodland WA
Jeanne
C20's Camper Spc/Sub
350 Targetmaster/454
Ive heard a bit about Por-15.... can it be put on OVER paint??? Prepped of course....
Speakfordadead
Woodland WA
Jeanne
I use Marhyde (One Step) which is similar.... but it goes on clear and turns black if it touches rust. Never used POR 15
MadOgre
NA
NA
NA
NA
NA
is marhyde a rust converter ?
Por 15 is a non porous paint/coating that etches to the metal. Can be had in black, grey and silver, they have other products too like chassis coat which is a top coat for POR 15 and is very similar to a factory matt black finish.
flyboy1100
UsA
me
k1500
The por15 metal prep completely dissolves the rust leaving you with bare metal. I have used it before but never on so much area
Speakfordadead
Woodland WA
Jeanne
Yes, Marhyde is a rust converter.... I use it because that's what I was taught to. Not because I know why. I've been mostly around race cars and rat rods. I'm not much into shiney. I get twitterpated around rusty stuff.... old guys beware.
MadOgre
NA
NA
NA
NA
NA
I think most rust converters are pretty similar. I use rust mort. Any way That is a good step before painting or coating with POR 15.
POR 15 is more of a full restoration type product, good for rusted areas and fully cleaned to metal pieces. I have a new frame that im gonna coat with POR 15 after I finish cleaning it down to the metal. Its a lot easier with no body on it :)
Heres some pics of some inner fenders I did. I forgot to take a pic of them coated in POR 15. The after pic is a coating of POR 15 top coated with their Chassis Coat.
Lugnut
Northwest Georgia
Jason
'79) 350/ granny 4-speed, '86) 350/A833 3-speed with overdrive
Installed new door panels and arm rest. Had to make a new trim section to go around the brushed aluminum panel the old plastic ones were shot.
MadOgre
NA
NA
NA
NA
NA
That looks pretty nice, better then new!
nixon22
