anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
454 TBI TH400 4:11 gears
had a rough day truck broke down on the main street. the ecmb fuse kept blowin . so I had to get towed home $120.. for 3 miles . so I got home and googled the problem . they said to follow the orange wire which goes to fuel pump relay and to the oil pressure switch. turns out the 2of the wires going to the oil pressure switch fused together . once I separated them everything was fine , so if anyone ever runs into this problem just look for the orange wire and see if its casing is messed up and touching something. :)
Man that sucks but at least you figured it out. Thanks for sharing the info.
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
Went to the junkyard yesterday and scored some good parts. Air intake duct, two intermittent wiper modules, under hood retractable work light and a hood release cable for 20 bucks.
MrMarty51
Eastern Montana
Martin
Thats a good deal.
I have not done one thing to Mine S.B. in a very long time. I did fire it up and drive it around, about last May, might have been April too.
Today, I am going to go to Mine sons and borrow His riding mower, I am taking the keys for the old brown beast along and fire it up and take it for a drive.
I have a steering shaft to install, thanks to 89 Burb, and then I want to convert it over to a TBI, that will have to wait for just a little while, The garage will need some cleaning out before that`ll happen. LOL
I now need to leave for a while, I will try`n get back here later today, affer the mowing is finished and the weeedeeeewakkker`n is all finished.
Nice about the back surgery, I can now do these things, if I am very very carefull.
Thanks for being here guys.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Howdy there, Mr Marty! Glad you are doing well!
Skweegle89
Oklahoma
Acquired a newer back bumper from Mr. Pickup. Also got a receiver hitch and a quadrajet to replace this ****** edelbrock. Got the white paint buffed off from where my dad backed his brand new Dodge into my tailgate. (destroyed his entire taillight assembly) but just left a bit of his paint behind. I love the quality of the bodies of these 30 year old trucks.
MadOgre
NA
NA
NA
NA
NA
What about the Edelbrock carb do you dislike. ?
I just put an 1806 eddy on mine. Haven't driven it yet. But im kinda disappointed with the idle quality already. I just wanted to get rid of leaky fuel well plugs and I had this brand new carb sitting around.
Im already under the impression that a good quadjet is far superior with out even driving it.
Skweegle89
Oklahoma
I can seem to get mine adjusted. It runs really rich and if I back it off it runs like crap. It probably needs rebuilt, but a buddy of mine had this good qjet he didn't need along with the intake adapter he just have me.
MadOgre
NA
NA
NA
NA
NA
Ya I am working on a quadjet or two. I figure down the road I can go back to the quadjet with that adapter.
Did your carb base gasket have the divider or was it open from side to side. ? Mine has the divider and I was wondering if getting an open one would fix the idle and off idle stumble.
Skweegle89
Oklahoma
Im not sure I haven't switched them out yet, but I will let you know when I do. Im sure they can be good carbs if a guy is familiar with them, but Im not and most of my help are qjet/holly guys so Im going to go ahead and switch and see if I can get it running better.
MrMarty51
Eastern Montana
Martin
WY Thank You foamy pirate.
I have not had much time to be cruising forums lately. It seems that them "Honey Doooooz", or, is it "Honey dues" caught up to Me.
The back is doing nicely and it is healing up, the wifey, She had a way of detecting this and will no longer let Meeee offt duh hooook. :shrug:
I will try and maker into here a bit more often and, hope I can.
In the B.S. on Craigslist thread, I posted about a 94 1ton dually crew cab, four weeel drive a feller in Reno is selling, diesel, 6.5, bad infecktors, I mean injectors.
Takeum peek, lemmeee know what You think.
He is going to email Me some pics. of the interior. I talked to Him on the phone a while ago.
OH well, here it is. takum peek atum.
http://reno.craigslist.org/cto/4598344632.html
Stewzer55
Ohio
Stew
R30
I got my ALDL-usb cable from Red Devil River today so I can read the brain of my TBI.
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
well I fixed the wires today they were bad in a couple of places were the orange wire was totally exposed. Even the oil pressure sending wire was really bad . I fixed them both with electrical tape , and then put them in a plastic wire loom protector , so it should be good for another 27 years lol.
JRandle
Verden, OK
Jesse
Chevrolet Silverado
Got the front end off today!
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
I started taking my front axle apart so I can install a limited slip in it.
Discovered a missing sway bar bushing when I was jacking the truck up to put it on jackstands.
Found the LH wheel bearing outer locknut had loosened and backed off, and shaved a little aluminum from the inside of the locking hub.
I hope it won't affect it.
The inner locknut unthreaded partially off, then stopped.
I had to use a 1/2" drive impact to get it off.
Good thing I have a spare set of good spindles and nuts.
Here's a couple pix of what I saw.
I'm not going to use that axle shaft, I have a good set of used ones already.
bajadiver
