Moderator Administrator
Notta damn thing. Got my K10 here at the tow yard and haven't had time to touch it. Gotta take advantage of this busy spirt the last 3 weeks, and now a driver quit so I get more work. I need the cash anyway.
MadOgre
NA
NA
NA
NA
NA
Picked up a set of 33 inch Goodyear Duratracs for under $1000 installed.
Brakes
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
Finished installing new heater core, new hoses, control switches and the cable I got from wrecking yard yesterday.
Put the dash bezel back together.
Cooked some fried chicken for lunch, now it's time to go back outside and finish getting the new gas tank switch and solenoid working.
If my pain pill would kick in, I will tackle removing the bench seat and tear up the old carpet.
It'll probably end up being a two person job so I better call a neighbor and see when he is available for a few minutes to help.
firebane
Calgary, AB
Curtis
Finished up removing the lifters out of the driver side. Removed rockers and pushrods on passenger side.
Removed alternator, power steering pump and water pump.
Trying to decide if the engine block is black or blue... There is that much grease and oil on the front of the thing. Oh also discovered front seal is shot so that will have to be replaced.
Went to remove fuel line for carb but they herculed it in so I had to break that off and will now have to pull the fuel pump.
Also didn't find any gaskets once again on the passenger side exhaust manifold LOL.
Hoping that once I'm done this top end work the bottom end will survive till next year.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
Removed the bench seat (to put a seat cover on it) and took up the old carpet so I can clean up the cab and lay down the new carpet.
This is what I found under the old carpet:
Including a 1954-S wheatback cent in real nice condition
Carb'ed Vortec 350
Getting paid to work on the truck...nice...:party36:
Hobbz
Ky
I started wiring my truck from front to back. Got all the heads/tails done and the steering column...
BADAZ chevy guy
Clearfield, UT
Doug
Didn't do anything to the truck, but I did build a transmission stand for rebuilding the 700R4 going in the truck.
350runner
tx
Ceasar
Mass production my friend...
datto62073
Monroe
Mark
nothing today but got some stuff from the bone yard yesterday. gotta take a few pics then update my build thread.
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
Drilled out the bushings on the 64" springs im going to put on after I get the flip kit and shackles.. pita
Hobbz
Ky
Got the wife to help me bleed the brakes today
oopsman_09
Nampa, ID
Aaron
sierra classic c1500
swapped out transmissions and converted brakes to hydroboost.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
I didn't do anything because it rained and now it's a mud bog outside.
I need a garage with a concrete floor ...........
holy6hxst
