I have noticed many of those "restricted" nipples over the years, but never put 2 and 2 together. I always just assumed that the nipple was a thick casting for some manufacturing reason.
My ignorant self has replaced them several times with more open fittings and never noticed a difference in heater performance. Maybe it doesn't matter so much, or maybe I'm just ignorant... it could be either, lol.
Or lucky. They restricted the flow to prevent heater core failures. We had one guy on here that his suburban wasn't warming up fast enough on the gauge. He said once he put the correct fitting in his problem was cured the heater core was bypassing too much coolant. I've only heard that once.
The Right side of Washington
Same.
Makes total sense but if I had to guess it may be for quicker warmup and the Heater doesn’t need full flow to pull good heat.
I do know a heater core and fan will pull a lot of heat off.
Used to cheat in demo derby and keep coolant in the system (rules were water only because 90% of cars would loose their coolant getting smashed.
I’d hook the upper and lower rad hose together and leave the heater cranked on high temp and fan. It was enough to keep the engine alive and you could go around smashing cars with the front of f your car without busting the radiator!
Edit. Dint read Rick’s last post before posting
Tank6x2
You’re Awesome Know That!
Lifetime Supporting Member
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Spending the weekend on mounting the new fuel tank /rear crossmember, ordering more insignificant/random don’t need now need later parts, Merry Christmas to all next week!
gilby959798
CLT NC
GMC K25 Camper Special
Working on the rust repair little by little
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Extra bypass may be another effect, but they're usually made with a restriction because heater cores can moan during acceleration if they're not flow restricted.
Terlingueno
Fictional Western Sage
Far West Texas
Skeeter
K20 Suburban
350/SM465
What does one of these "restricted" units look like?
Terlingueno
Far West Texas
Skeeter
K20 Suburban
350/SM465
Bottom right corner of the manifold
Were they only on Corvettes? I am using the OEM unit off the original manifold on my Edelbrock and I don't think the hole is that small in diameter.
No it wasn't just on Corvettes. I don't have a definitive list as to whether every small block Chevy made had one but even the smog dog 71 307 that I checked for @PrairieDrifter had one.
Old Guy Bill
KY
Bill
Almost every heater hose system in that era had two hose sizes, 5/8" on the
restricted (outgoing) and 3/4" on the input side of the core.
Terlingueno
Far West Texas
Skeeter
K20 Suburban
350/SM465
Mine is 5/8" from intake to core, 3/4" from core to radiator. The ID of the unit in Ricko's pic looks smaller than the ID of the one on my truck. Perhaps my eyes/memory is fiddlin wid my perception
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I've done the exact same thing. We're the smart ones ya know :rofl:
"nEeDS MOrE fLOw" :laughing1::laughing1::laughing1:
****** hilarious lololol
xm20k
Girard, Ohio
You have that backwards 5/8 feeds the core and 3/4 is the out flow. The different hose sizes are to maintain an optimal pressure differential as the fluid expands into the larger space of the core it also reduces back pressure and slows down allowing for more contact time to transfer heat.
Gm used to use 5/8 for both untill the late 50s. The inlet is almost always on the lower side to prevent noise from air flowing into the core and causing a gurgling or burbling noise.
jw23655
