Vintage Air Firewall Installation
Finkaire
Finkaire
California
Loren
Silverado c10
I would run the hoses directly through the firewall to the evaporator, if you use a block or connections on either side of the firewall it will leave 4 unnecessary places to leak
Doppleganger
OH-MI: Just like it sounds
There is a heater control valve that goes inline of one of them, but the more I look at this mess the more I am thinking the same thing.
There is a place locally that makes custom pressure hoses (including AC) for anything. I'm taking some of these VA fittings there tomorrow AM and see if we can improve on them.
Finkaire
Finkaire
California
Loren
Silverado c10
Custom hoses are a good way to go. However A/C lines are rated at 500psi, and no shop i know can test them more than say 125psi. Make sure if there is a problem that they will cover a re-do
Doppleganger
They made a place my buddy worked at some lines rated to 2500psi. Every time I'm there someone from ODOT or a couple local stamping plants are there.
I used to restore 4N cars and there was a high pressure line that had been out of production since 1993. I found one (that was bad) and they duplicated it for me probably 8-10x. Never an issue.
Doppleganger
It's not that critical, the rubber grommets allow some movement in the lines.
I did fab a small bracket to hold the heater line valve to the fender well, I didn't like it hanging on the hose.
I hate to ask this....but there is a method to my madness.....but how wide is this area here? THANKS.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
But… but…
The left limit of the requested measurement has no specific point?
I can probably get the measurement from the heater hose to the dip in firewall….
I’ll try to remember in the AM
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Shoulda done it tonight and took a Bullet with ya ;)
Doppleganger
But… but…
Trying to find the space between the hoses and that bell housing edge. I have never had any use for the cheap overflow tanks the SBs had - never cared for how they mount either. I have bought 2 and both leaked. Read a posting once where a guy bought 4 to get 1. I like the 95-98 styles - mount is better too. Want to see if it will fit there or do I have to move (or hide :naughty: ) those HVAC lines.
Here is a ballpark mock up of about where it originally went - I think I can move it some. Just needs to clear the hoses and dont want it too close to the motor.
CalSgt
CA
Casey
CalSgt
CA
Casey
in message 7 you posted an illustration labeled figure 1, I wondered if you had figure 2 or more and or text and if you could post it?
pls?
Ah... Gotcha, that was a screenshot of the vintage air instruction manual.
Here's a link to the instructions for a square without factory air conditioning. There are several other instructions on the website if needed.
https://vintageair.com/content/751619.pdf
Old Guy Bill
KY
Bill
Sorry I've taken to get back to you but the wife and I been out on the road with our RV.
It looks like 10-11" in that space..
kfrdavid
