Upgrading to POSI rear end, went very smooth,
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
85K304SPD
Las Cruces, NM
Richard
Tell us what all they did and about how much it costed, please.
born2Run83
West Texas
Justin
GMC - C1500
5.3L LM7
Did you have a higher spline axle put in as well? Looks good from what I can see
Going posi is easy,you don't even have to shim the pinion. Price the posi carrier of your choice, differential bearings, and a pumpkin gasket. Swap your ring to the new carrier,use your new diff bearings,set your backlash and your done. It's way easier and faster than R&R a rear end. Homemade tool for pulling and pressing Diff/Pinion bearings if you replace pinion bearings and seal, buy a crush sleeve eliminator,it will make your life so much easier.
Original
