Truck wants to die after few min of driving
gwandro
Red Bud, IL
Grayson
Scottsdale
I have a 82 Chevy k10 with a 350 in it
I’ve been trying a bunch of different things to fix it.
After maybe about a few minutes of driving it wants to die down and lose power sometimes almost shutting off but doesn’t. I’ll go over the things I’ve replaced
Did the cap and rotor first
Then bought a whole brand new msd distributor
Tried brand new carb
Rebuilt old carb
Brand new fuel pump
Has brand new plugs and wires
All the timing was adjusted
After all this it still runs perfect until I get a few minutes down the road and just wants to die
Rebuilt old carb
Brand new fuel pump
How did this problem start?
legend57
San Jose, CA
Rob
Get a fuel pressure gauge and monitor it. You could be picking up crud from inside the tank and collecting it on the sock at the pick up. This will fuel starve the engine. Once you shut it off, the crud falls back to the bottom of the tank and it will run fine for a while. I went through the same pain on my '57 Chevy. I went through the ignition, carb, fuel pump, etc. Only fixed it when I had the tank cleaned.
Do you have the charcoal cannister hooked up correctly it is the vent for your fuel tank.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Definitely sounds like a fuel issue like sucking air maybe.
gwandro
Red Bud, IL
Grayson
Scottsdale
Did you clean the tank or someone else? Researched and seen one about muriatic acid cleaning I think I’m going to try and I ordered a new sending unit
legend57
San Jose, CA
Rob
I took the tank out and had it professionally cleaned and sealed. You could give it a try yourself. Just be careful with that acid.
legend57
San Jose, CA
Rob
I highly recommend adding a fuel pressure gauge inline. It'll be useful for debugging now, and in the future.
The Right side of Washington
Well OP ain’t come back. Sounds fuel related hard to play free internet mechanic when the person asking advice don’t provide info….anywho…
Sounds fuel related. Spark doesn’t generally “go away slowly.”
Drive truck. When it dies pump carb, check for fuel squirting. Accel pump won’t squirt if the carb is dry. Squirt fuel down carb, does it fire?
And if all those things you did provided zero change, likely good thing is you didn’t screw up any of those likely needed maintenance/repair items and can cross them off the list. Other good news is it’s something else.
Check tank and pickup. Run it off a fuel can if it doesn’t die, the problem is upstream of the fuel pump.
Dave7968
